Hey everyone, I have a 37 Ford bobber type truck with a 37 hood top, stock to fit the 37 cowl but modified to fit a 32 shell. I only run the hood top and it gets old taking the hood off just to check the radiator. What are you guys using for hinges? Thanks in advance
Right now I have some square tubing from the firewall to the radiator support with some holes drilled to accept `some pins that are welded to cross braces under the hood. Two in front two at rear. It's a pain lifting the hood off all the time for maintenance etc.
