Homemade penetrate oil works best
Discussion in 'The Hokey Ass Message Board' started by RDAH, Dec 20, 2012.
  1. RDAH
    RDAH
    from NL, WI
    This test was published in my "Quicksilver" IMOA Mercury mag. on some bolts that where all chemicaly rusted & the same size.
    No penetrating oil = 516 pounds of torque
    WD-40 = 218 pounds
    PB Blaster = 214
    Liquid Wrench = 127
    Kano Kroil 106
    ATF + Acetone mix home brew of 50/50 = 53 pounds
    ATF + laquer thinner also works better then any over the counter product.
  2. hd4unm
    hd4unm
    this went around the block about a week ago.
  3. hotcargo
    hotcargo
    I been doin' this for at least 50 years
    one part Auto trans fluid ....one part Mums nail polish remover ( acetone )....
    mix up a small amount and keep in a glass jar ..always worked like a treat on stubborn bolts and nuts etc
    my dad taught me ( I wonder if his dad taught him , there were no automatic gearbox's around then .....ha ha )
  4. go-twichy
    go-twichy
    i'm up for a weekly penetrating oil update! maybe daily at 12:00 noon and right before i go to bed.
  5. nickles street chop shop
    from Edum Tejas
    What if you were to keep it on a spray bottle instead of a glass jar?
  6. hotcargo
    hotcargo
    OK Nicko , the acetone gradually fucks up the plastic plunger pumps in some of those spray bottles .............and also doesnt evaporate in the glass jar
    I've always used the glass jar and an old wooden handled horse hair type brush and just dab it on
  7. nickles street chop shop
    from Edum Tejas
    that's what I figured. I'm going to mix me some up tomorrow. I have a lot of jars for cooking and shit. Good thread.
  8. ok, maybe a dumbass question, but how long after applying this concoction do you let it sit before you try to break loose the bolt or nut?
  9. lawman
    lawman
    Thank's Guy's for the info ref to glass jar's.I had the same question about the plastic bottles.
  10. fsae0607
    fsae0607
    So... Dexron or Type F???
    j/k cool I will be making some tonight and try it out! Gotta lot of rusty bolts on my 61.
  11. SaltCoupe
    SaltCoupe
    from Indiana
    ^^^now that's funny shit right there^^^
  12. mikhett
    mikhett
    from jackson nj
    i keep it in a steel spayer bottle that u charge with compressed air from my compressor.works like a charm
  13. Jalopy Jim
    Jalopy Jim
    to post #8 I usually apply some every 10-15 minutes and use a six sided box wrench and keep trying until I can loosen it bolt wit a box wrench. Very few get broken off that way.
    I will be starting my Falcon rebuild after the first of the year.
  14. mlagusis
    mlagusis
    How about one of those old oil can squirters??
  15. squirt can will work for applying but you need to store it in a closed/sealed container. acetone has a way of evaporating.
  16. parklane
    parklane
    I've put it in a WD40 plastic spray bottle, and seems to keep in there.
