Im building a valley pan and bought a blank and I'm looking for ideas on what tube and breather that you used. I'm going with stock stub up look for my 92
I fabbed my valley pan for my Hemi. Made a sheetmetal pan or tray. 3"x6"x 1" like a box. Screwed it to the bottom of the aluminum valley plate. Ran a 3/8" copper line to the center of the pan. The pan acts like an oil baffle. The 3/8" line runs to rear of valley and makes a 90deg thru the aluminum plate. then up thru a 500 Cadillac PCV valve. Screwed a 1/2" pipe for oil fill with a machined adapter with a breather on top. The sheet metal pan has no holes other than the leakage at the top were it is attached to the aluminum. The idea is to keep oil spray from entering the PCV line.
