I'm shortening an Early Ford hollow drive shaft and changing the spline from ten to six. The spline adapter I have fits into the hollow drive shaft but is a little loose (.030). I have figgured out how to center the adapter before welding but am looking for ideas on how to hand rotate the drive shaft so it can be checked with a dial indicator. No lathes or fancy equipment here, just hammers, torches and welders. Thanks in advance for any suggestions.
I have done tailshafts by fitting to trans & diff ,jacking up rear end setting up a dial indicator & getting a mate to spin rear wheel . Tack weld carefully then remove & fully weld.
Make some v blocks out of scrap and spin it around, indicate off the ends. Done it many times. Not sure how you're going to center the end, but I've done it by making a thin ribbon out of shim stock that fits between the tube and end.
