Technical Holley fuel pressure regulator line size...help!!!
Discussion in 'The Hokey Ass Message Board' started by Blacktop Graffiti, Apr 14, 2018.
  1. Blacktop Graffiti
    Blacktop Graffiti
    I have your average Holley fuel pressure regulator and I tried to run fuel line and it's too loose and the line itself can move in and out. As in it doesn't seal.
    Is there a special line that I need? I don't want to run AN fittings.
    Thanks!
  2. greybeard360
    greybeard360
    Photos would help to see what you are dealing with.
  3. Blacktop Graffiti
    Blacktop Graffiti
    Here you go.
  4. greybeard360
    greybeard360
    Ok.... So what does the fitting look like you are trying to screw into it? That takes 3/8 pipe fittings... They make barbed fittings that fit for 5/16 and 3/8 fuel hose.... Ace Hardware, Lowe's, even auto supplies.
  5. Blacktop Graffiti
    Blacktop Graffiti
    It's just a standard 3/8 fuef line.
  6. razoo lew
    razoo lew
    from Calgary
    Those look like 3/8 NPT. Pipe thread, not meant to screw a fuel line fitting into. You mention “fuel line moving in and out”, sounds like you need an NPT adaptor to tubing fitting adaptor of some description.
    swade41 likes this.
  7. Sounds like you need a 3/8 NPT to 3/8 flair nipple
    Phil
    Johnny Gee, Scott and swade41 like this.
  8. mutant55
    mutant55
    Agreed, 3/8 npt on the outlet ports, but it’s 1/2 npt on the inlet port on the bottom. I have used those regulators for years.
  9. squirrel
  10. Mike VV
    Mike VV
    from SoCal
    Simple really -
    What mutant55 and squirrel said.
    Mike
  11. jimmy six
    jimmy six
    Carry an extra...for me they have been known to fail. Replaced with one from Aero Space Industries.......no more failures.
  12. Mine is made for a 3/8 line. I suppose you could use an AN fitting, I am just using hose barbs on mine and a little stub of flex line. It makes it easy to plumb and also serves as a vibration damper.
  13. Blacktop Graffiti
    Blacktop Graffiti
    Yep I'm using the barb style. It works great!!! Thanks everyone.
    Sent from my SM-J327P using The H.A.M.B. mobile app
  14. Bandit Billy
    Bandit Billy
    This is mine, Holley 12-841 I think. 3/8 NPT inlets and outlets, I went the other way and converted NPT to AN fittings
