Technical Holley Carb ID
Discussion in 'The Hokey Ass Message Board' started by jackalope, Jan 16, 2018.
  1. jackalope
    jackalope
  2. wheeltramp brian
    wheeltramp brian
    600cfm with 4x4type vent tubes?
  3. jackalope
    jackalope
    It looks like a Holley Avenger for trucks. Any reason I couldn’t use this? I don’t plan to be off camber but free is good in my book
  4. jackalope
    jackalope
    It’ll go on a carb’d and distributor converted non HAMB friendly GM motor
  5. It's pretty hard to beat that price!
    jackalope likes this.
  6. squirrel
    get it, and then read the number stamped on the choke horn, and we can identify it for you
  7. Rich S.
    Rich S.
    Looks like a 4160 with the off road vent tubes?
  8. Deuces
    Deuces
    from Michigan
    I got this one for next to nothing.... I was a happy camper when I checked the List #....:D:D:D:D:D 134265360413824.jpg
  9. jackalope
    jackalope
    Okay, in order to get the correct number for ID, where should I look? I heard the choke horn. How long is the number. I didn’t see much anything.
    Lastly, and more importantly, any reason NOT to use this on the street or any changes to improve for street use.
  10. 19Fordy
    19Fordy
    If you Goggle "Holley Carb List Numbers" you will get the answer. Here's a start.
    ww.mortec.com/carbs.htm
  11. Deuces
    Deuces
    from Michigan
    Take a close up picture of the front of the choke horn and post it on here....
  12. seb fontana
    seb fontana
    from ct
    The numbers are in the pic you posted, looks like a smudge.
  13. jackalope
    jackalope
    I’m told it is in fact a Holley Truck Avenger. Not sure cfm but by all accounts and visual description, it is an Avenger.
    Now, back to the crux of the matter. Any downside to running this and if so, can anything be done to improve on street. Basic 350hp later model GM engine.
  14. squirrel
    like I said, get the carb, tell us what that stamped number is, that is visible in the picture but too blurry to read.
    They make a bunch of sizes of Avenger carbs, we'd be guessing if we tried to tell you it would or would not work for you.
