Ok, I have a list # of 9219 2021. I know it's a 4160 model. Can someone tell me all the specifics on this or where I can find the info? I have looked on all the websites and have found nothing. Would like to rebuild, but need info. Thanks
It's a 600cfm 4160 (as you know)....the Renew Kit is 37-1536 and the Trick Kit is 37-933 (Holley numbers). It originally used a .031 pump nozzle; a black sec. spring; and a secondary plate with .073 main holes/.029 idle holes, if you want to check for modifications.
i was woundering if anyone could help me with this one. i have a holley model 4160 list number 6515 i cnt find what the cfm is does anyone know? thanks for your help.
I have an old holley and the number on the carburetor are: RB 4011-3 1887 Does anyone know anything about this carb?
------------------- Actually on model 3310 Holleys using either the 750 or 780 rating is correct and depends on what you want to call it. The original 4150-series (ie- with the secondary metering 'block') "List 3310AAS" carb was an OEM Chevy carb used on 375-HP 396 Chevelles and Holley rated it at 780 cfm. Later when Holley came out with aftermarket versions of the carb - both in 4150-series versions and the cheaper 4160-series (ie - with a secondary metering 'plate') they were still rated at 780 cfm in the earlier catalogs and then, in later catalogs at 750 cfm. However the carbs never changed - the early and later versions (both 4150 and 4160 versions) flow *exactly the same* and the *supposed* 30 cfm reduction in airflow rating was merely done for marketing reasons - to simplify cataloging and to make carb better fit into the Holley line of carbs in nice even 50 cfm increments. Mart3406 ========================
I have a Holley with List-3796-1 Above that # is C8OF-9510-0 Did it come on a 1968 Ford ? What CFM is it ?
Here's a link to Holley's "official" carb list number chart. http://www.holley.com/data/TechService/Technical/Carb%20Numerical%20Listing.pdf
They are different. I have both carbs. First ones rated at 780 had downleg boosters. 750 ones have straight boosters. Downleg boosters restrict the airflow less, thus the different rating.
My 1978 Holley Illustrated Parts&Specs Manual lists it for 1967-68 Comet, Cougar, Mustang and Fairlane 390 engines.
3796 is the 4V 600cfm Auto Cal. Emisssion per mustangtek.com (happened to be researching a carb as well) Found the post by using the SEARCH !!!! Thanks to all before me, great stuff.
I just got a 1982 holley book...shows the 3796-1 is the 1968 version of the 390 auto trans carb used on mustang/fairlane/cougar/comet Neat book, has more numbers in it than I can shake a stick at
I've been searching today to find out what CFM my Holley is. I found out the carb is from a 65 Chevelle HP 327 #3043 595 CFM. I called the Holley Tech line. The guy was really helpful.
Please help identify an old Holley four-barrel. It's a square bore with 1-7/16" bores. On the left side of the air horn is stamped "124." On the right side, the first line reads, "C1TLE 9510-AN." The second line reads, "LIST 2349." I've been to a dozen or so sites trying to find that LIST number, but I've had no luck. I'd like to know the common-usage model number and the CFM. Thanks.
Hey fellas, I got a stumper I can't find these carbs in the book or site. They are on a tunnel ram, single feed like a 1850 600 cfm. The only two numbers are 5776 0276 same on both and the front bowl on the carb says Holley since 1930 or something like that. thanks
I called the Holley tech line and he thinks the first number is a 9. The funny thing is that I was reading one carb while another guy (Fullfendered) was reading the other, we both thought either 5 or an S. The tech said that they would be 450 tunnel ram carbs which sounds right, not that it's worth anything but they are on an Offenhauser tunnel ram. thanks for the help though
What model Holley (?) is that wacky round 4bbl carb that is a spreadbore design, but the bores are REALLY far apart? Something like a TQ replacement carb? I know it was a small CFM, like 450 or so. Maybe good for a slant six? No mistaking when you see one, its like "WTF is that?" PS>> Holley economaster "baby quadrajet"..Any good or just wacky?
i have a holley with numbers 1850-5 on bottom of that its 1349 and on top it says 6r 7809 can any one tell me anything about this carb...
4150-G 1961 Ford Trk., 312 Eng. From this site, http://www.tocmp.com/manuals/Carbs/Holley/MasterList/index18.html.
That would be a 302 engine designation-Not a 312-missprint No 312 engines were ever installed into trucks from the factory. Oldmics
