Technical Holley 94 flooding (video)
Discussion in 'The Hokey Ass Message Board' started by moskit, Mar 5, 2016.
  1. moskit
    moskit
    from London
    Guys is that what should happened?
    Thanks for any advice.
    Sent from my ALE-L21 using H.A.M.B. mobile app
  2. Kiwi 4d
    Kiwi 4d
    A little history on the carb would help, rebuilt etc. If you rock it around as in the video fuel will exit. But I would first double check the fuel pressure with a known gauge. Could be float level too high or needle not seating properly.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Is your throttle open or closed when you apply pressure??? If open yes you will get fuel flowing like that. If it's closed laying flat without tilting no fuel should be exiting. A lot of possibilities. Stuck or incorrect float adjustment, reversed nozzle bars, defective needle valve, incorrect jets and power valve fitment. A lot of poor fitting power valves on the market. If these carbs were rebuilt I would tear it down and begin again. Buy your rebuild kits from Dickster here on the Hamb.
    http://dickshotrodcarbs.com/home.html.
    Ps. If it wasn't for George and the boys, I too would have an accent like that. :)
    1927graham likes this.
  4. moskit
    moskit
    from London
    Carbs are rebuild with vintage speed kit. all 3 are the same... but, procomp stuff is shit. disconected it all and fired up straight away
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Congratulations first fire is a good feeling. . You're still going to want to change the jet size and possibly the power valve when running dual carbs.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    The original distributors on those engines are poor to say the least. They require a Venturi vacuum from your 94's. Running two carbs doesn't provide enough vacuum for this distributor to advance properly. GMCbubba here on the Hamb sells a distributor for your needs with years of quality and good service.
  7. Blues4U
    Blues4U
    from So Cal
    I'm not familiar with Holley 94 carbs, so will defer to the experts, but the first thing I see is that you cannot rely on that pressure regulator alone without a pressure gauge. IME the numbers on the regulator do not correlate very well with the actual pressure allowed, you really need a gauge. It is very possible that the pressure is overriding the needle valve and allowing fuel to overflow the float bowl, and from there the fuel is being pushed out through the idle jet or even the main jet and flooding the carb. Put a gauge on it and be sure of what the pressure actually is.
    Petejoe likes this.
  8. moskit
    moskit
    from London
    Got the gauge fitted, but it`s normally with 3 carb setup. i pump now somewhere around 1.5 psi... i feel great now you know. hope has return and at least i can carry on. speedwaymotors must exchange that procomp ecu and than i fit this with magnetic pickup distributor that i intended to use,
    Petejoe likes this.
  9. You did check your floats for leakage by putting them in hot water?.......You can run up to 2.5 PSI fuel pressure. Power valves will depend on your running vacuum. Running together I would start with 3.5 PV's. Make sure you are using the flat PV's or the thick gasket with the (new style) tapered valves. Change your distributor to a modern one using manifold vacuum, you will VERY happy with the results. call Bubba.........Rick
  10. moskit
    moskit
    from London
    See i have modern procomp dizzy and cdi ignition. Could't get it to fire.... Took that cdi unit to work stripped and measured all and guess what..... The coil wires are in wrong color/polarity. Black is positive and orange is ground where instruction state opposite. Haven't run it yet... New movie on Friday with more results
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    Hope you notice we keep going back to more carb work. Even with your procomp working, please be sure to tend to that.
  12. moskit
    moskit
    from London
    Sure thing Petejoe. It's next on the list. What I'm thinking is maybe hookup oxygen sensor as some kind of exhaust analyser
  13. Glad I found this thread, my question is in regards to a red ram hemi with 3 of these on it. I had fuel pouring out the headers and in the pan. The engine was temporarily hydro locked. Would these problems mentioned be caused by what others have suggested?
  14. Mike51Merc
    Mike51Merc
    Why'd ya remove the videos?
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Please make a new thread on this subject instead of confusing the issue with two different engines and different problems.
  16. All I asked is if the problems could be related. Didn't feel people would be that confused about it. A sole yes or no would have worked, god damn.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Sorry Nick didn't mean to upset you. But your question would lead to more questions and before you know it we would have two conversations going on at the same time. If you'd like my quick answer it would be yes.
  18. Thats all I needed to send me off in the right direction. Very similar problem and induction set up, but happens with the engine off instead of running. I'm on the right track now, just didnt want to get shit for starting another thread thats been covered before. Thanks.
    gimpyshotrods likes this.
  19. gimpyshotrods
    gimpyshotrods
    I hope you get it going. It would be nice to have ever see anything I worked on in public. People are starting to call me a liar.
    Traditional?
  20. It was running super killer on Saturday and on Monday. Then yesterday it fucked up. I started another thread about the problem.
    Petejoe likes this.
