Technical holes in bolts
Discussion in 'Traditional Hot Rods' started by terry k, May 18, 2016.
  1. terry k
    terry k
    from toledo oh
    Looking for help in setting up and drilling holes in bolts for safety wire and cotter pins.
  2. 302GMC
    302GMC
    from Idaho
    Stick them in a piece of copper tubing, clamp in vise, drill away ...
    clem and LOU WELLS like this.
  3. 117harv
    117harv
  4. Blue One
    Blue One
    from Alberta
    A hole in a bold :confused: Hmmmm :D
    tfeverfred, Johnny Gee and 1927graham like this.
  5. bonzo-1
    bonzo-1
    Drill a hole in a nut, thread on bolt and use nut as a guide. Use a drill press and vise of course. Two nuts can be locked together if the bolt moves around.
    patmanta and clem like this.
  6. seb fontana
    seb fontana
    from ct
  7. rustynutz
    rustynutz
    I use the nut method, except I drill thru the nut and bolt at the same time, then reuse the nut as a guide if I have multiple bolts.
  8. Speedwrench
    Speedwrench
    FWIW - Speedway also has the drill fixtures.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If your "bold" enough ? Drill some holes on your nut's, I mean one nut then thread it over your bolt along with the second nut to jam them. This way your nut's won't spin while your drill'n. :eek: ;) :p :D
  10. seb fontana
    seb fontana
    from ct
    Post #5
  11. tfeverfred
    tfeverfred
    Easy, Blue. You're heading towards the dark side.;)
    Blue One likes this.
  12. tfeverfred
    tfeverfred
  13. Ron Brown
    Ron Brown
    I hate it when my nuts spin...
    Johnny Gee likes this.
  14. Engine man
    Engine man
    from Wisconsin
    I rather enjoy it when mine spin!
  15. Mine stopped spinning years ago. ;)
    Johnny Gee and Ron Brown like this.
  16. seb fontana
    seb fontana
    from ct
    Does clanging count?
  17. Don't let them clang in stormy weather, if your from Mass.
  18. I think I tripped over mine today.
    I think that's what she said - "be careful you'll trip over your nuts"
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sometimes thing's have a way of being mysteriously familiar even when there not.
  20. terry k
    terry k
    from toledo oh
    This is out of control because of one fat finger !!!! Thanks for the suggestions. Johnney Gee you scare me !!
  21. Kerrynzl
    Kerrynzl
    A Grinder is the secret
    Grind a flat piece on the thread so the drill bit doesn't walk , then clamp it in a drill vice.
    Where the hole comes out the other side, clean that up with a grinder so the nut threads on easily.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'm just a very imaginative person is all. Seem's you are also ;) :cool:
  23. 56sedandelivery
    56sedandelivery
    Why not just buy them pre-frilled from a bolt/nut supplier? Being close to Boeing, and having neighbors/friends who work for Boeing, I get bolts/nuts from them all the time. Some are made of lightweight material though (aluminum or titanium?). Just a thought. Although I personally have never drilled bolts/nuts, I do have a very high dollar, stand-up, drill press I bought for cheap from a cousin who needed the money. I've only used it a few times in 20 years.
    I am Butch/56sedandelivery.
  24. patterg2003
    patterg2003
    Aircraft Spruce & Wicks Aircraft sell a good selection of drilled bolts that are relatively inexpensive. Just be careful how with the part number as they supply the bolts w/o holes or holes in the head or threaded end. Or as mentioned you may get what you need from an aircraft maintenance shop. I have bought a lot & need to order some more this week.
    Glenn
  25. Just about every bolt on Model T's used castle nuts and cotter pins, so you can get old-style (thick head) drilled bolts from Model T parts suppliers. Lang's Old Car Parts has a good selection and great service.
    Blues4U likes this.
  26. terry k
    terry k
    from toledo oh
    Thanks for the info........
