What size fuel line for hilborn stacks on alky or An fitting size ,small block.can i feed it with a block alky fuel pump.
It needs a Hilborn or similar (Enderly) type pump. Not the kind of pump that is made to use with a carburetor.
Thanks Guys i have no expierence with fuel injection only alky carb and we also ran a #6 line. I guess i will have to pic a path and stick with it i currently have a alky carb set up but for a vintage car only tubes will be correct.
-6 would be my suggestion as well. You can feed it with a belt driven pump. They are actually becomming real popular with the nostalgia nitro crowd.
