Technical hiding heater hoses on cars without hoods
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Sep 1, 2019.
  1. 5window
    5window
    What's keeping those hoses on the fittings?
  2. LM14
    LM14
    from Iowa
    Notice my last sentence. “No clamps yet”.
    SPark
    kidcampbell71 and 5window like this.
  3. Roothawg
    Roothawg
    So what is holding the hoses on? :)
  4. 5window
    5window
    Hi,sorry, I read it too quickly. May I ask why uoi didn't put the clamps on when you put it together? Depending on how long those hoses sit like that, it might be more interesting getting them apart.
  5. LM14
    LM14
    from Iowa
    They have been on there a week. Not a big deal at all. Will put clamps on this week after my next parts store run. Just a little detail. Working through each area of assembly on several fronts, no need to rush into putting clamps on until it gets coolant in it in the next couple weeks.
    SPark
  6. LM14
    LM14
    from Iowa
    The barbs on the ends of the steel lines are inside the hoses. The hoses are fit correctly so all the clamps do is seal the connectors. Shouldn’t need clamps to hold hoses in place.
    SPark
  7. 5window
    5window
    "Shouldn't" and "don't" aren't always in agreement.
    Baumi and nunattax like this.
  8. LM14
    LM14
    from Iowa
    True. Maybe what I should have said is "during mockup". With molded hoses cut correctly nothing is under any pressure to stay in place during mockup. It all fits correctly and stays in place. Everything will get clamps on final assembly, it's not rocket science.
    Below is a picture of what the end of the steel tube looked like before welding. The hose barb was pressed into the steel tube, everything was chamfered then welded. Then it was turned back smooth so the hex part of the barbs disappeared. A normal hose clamp will be put on each hose on final assembly once the system is ready to fill with coolant.
    SPark
  9. Some one told me back in the 50's that real Hot Rods don't need heaters . So I threw mine away ! Sorry just couldn't help myself on that one ! IMG_2215.JPG
  10. 5window
    5window
    Kept a heater (under the dash, but I dismantled and removed the AC.. But, if I lived in the southwest and ran a closed engine compartment, I could have done it the other way.
  11. nunattax
    nunattax
    WIRING down the A pillar in 3/8 or 1/2 inch hose clip to frame to its destination
  12. They have a function, so make them neat and drive on.:cool: I do not have a heater in either of my 32's. that I own now. I have in the past and like I said, made them neat and functional. After all they are Hot Rods.:rolleyes:
    Ron Funkhouser likes this.
  13. boo
    boo
    from stuart,fl.
    Take the heater out, don"t be a wimp. In 1961 i bought a new ford starliner and to get a heater was an xtra $18, , never got one. PLUS now we have global warming, you won"t need one.
    ct1932ford likes this.
  14. goldmountain
    goldmountain
    Here is heater hose hiding taken to the next level. Saw this car at Deuce Days this year looking every bit as sharp. Scan-190923-0001.jpg
  15. Stephen Barrett
    Stephen Barrett
    I should probably put windows in my doors before I get heat.;)
  16. fastcar1953
    fastcar1953
    That's clean
  17. blue 49
    blue 49
    from Iowa
    I don't have door glass and the heater still helps extend driving season.
    Gary
    patmanta likes this.
  18. Bandit Billy
    Bandit Billy
    If I see that correctly, the fuel line and heater lines are hard lines from the block to the firewall. That wont work for long with a little engine movement. Just sayin. unless I'm missing something.
  19. lostone
    lostone
    from kansas
    ^^^^agree^^^^
    So I say trailer queen.....
    5window and Bandit Billy like this.
  20. fastcar1953
    fastcar1953
    There are flexible lines at firewall
    patmanta and Raunchy like this.
  21. Stephen Barrett
    Stephen Barrett
    Yeah you're right. I was just joking but I do want both. Maybe a windshield wiper too. Just got my car on Friday. Doing new brakes and directionals right now so the other things will have to wait.
  22. bigdog
    bigdog
    My 02 Dodge uses a small auxiliary electric pump to help circulate water through the heater. A person could probably hide one of those inside the car up under the dash and run both hoses of the back of the motor.]
    greasemonkey54 likes this.
  23. Rob28
    Rob28
    from Calgary AB
    Timely topic
    Gave me some ideals. I ended up using a couple 90 moulded hoses and some copper pipe and fittings to route the one line under the header and then up to my heater connection
  24. 26hotrod
    26hotrod
    from landis n c
    Lot of good ideas especially for cars with no hoods...…….
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Really nice job.........Where did he hide the A/C ?;)
    While I like the pictures and ideas presented here, I was wondering......Would the push on type of hose that is made for air lines (175+ psi) work for coolant hose and get rid of unsightly hose clamps ? I've never had an air hose problem using that kind of hose.....but the temperature is lower.
  26. 36cab
    36cab
    My buddy Matt has a hoodless 32 5-window with a SBC. He ran an elbow off the right head with a short polished stainless steel line to a hose that goes to the heater core. He also added shutoff valve to the hose before the heater core. He then built a polished stainless steel line that runs from the water pump back near the elbow for the return. A hose runs from where he terminated the SS line to the heater core. The elbow and most of the SS line are hidden under the header.
      93 KB
      93.2 KB
      92.1 KB
      88.4 KB
    Shadow Creek and TagMan like this.
  27. fastcar1953
    fastcar1953
    I still haven't had time to do this. Thanks for reply's. The last one looks like something i had in mind.
  28. whitewallwilly
    whitewallwilly
    I know there not hidden,but kept them as neat and tidy as i could IMG_6396.jpg IMG_6394.jpg
