Technical Hidden hinges 30/31 roadster doors
Discussion in 'Traditional Hot Rods' started by CadMad, Nov 9, 2018.
  1. CadMad
    CadMad
    D947D9DB-5B5A-4C14-A280-41E7CF0601AB.jpeg 06897C48-D8FD-48C1-BB85-9B31204740C4.jpeg F15F548D-69A9-4EE2-8CBE-D9D92010B713.jpeg I picked up a crusty roadster door the other day . So I decided to fab up some doors in the evenings whilst I’m workingaway in Perth for a couple of weeks. I’m gonna build a roadster back with some 40s custom ideas like sunk number plate and shaved .
    I have a nice roadster cowl but no hinges. A hinges are expensive!
    I’m not adverse to hanging them suicide or with hidden hinges.
    Any ideas ?
    X38 likes this.
  2. I used 26/7 model t hinges on my 28 roadster pickup. I just had to lengthen the flats and redrill some holes. Model t's are/we're everywhere around here. Open model A's not so much.
    30/31 Open car hinges sure look the same as 28/9 Open car hinges by a quick look at Google images. Here' some pictures of my modified hinges.
  3. CadMad
    CadMad
    Just been advised that you Yanks don’t refer to them as “Improved” . That’s apparently an Aussie slang term for 30/31. Anyhow, either way will look forward to options.
  4. sloppy jalopies
    sloppy jalopies
    Closed car '30-'31 A hinges are a bear to find and can run up to $50.00 each...
    they are forged, the A roadster hinges are stamped and are 1/2 the price...
    the roadster pin tubes are not welded, just stamped / rolled...
    the roaster's are not super strong, bet you could weld a steel tube to a flat strip to make your own...
    make cardboard templates and transfer the hole locations to your hinge... DSCN3426.JPG
