Hot Rods Hey Hemi Gurus
Discussion in 'The Hokey Ass Message Board' started by 46Chief, Jun 18, 2019.
  1. 46Chief
    46Chief
    I'm putting a T5 trans behind a 55 Hemi using Hogshead and this no name adapter. The question I have is it necessary to have a steel or aluminum plate sandwiched between the block and adapter for support? Is there a stock plate that covers the bottom of the flywheel? Thanks
    Also opinions on aluminum flywheel w/insert vs iron flywheel for mild street hemi. 20190618_121952.jpeg 20190618_121940.jpeg
    Sent from my SM-G965U using The H.A.M.B. mobile app
  2. Stay away from the aluminum flywheel... while they're great in sprint cars for instant throttle response, they're not street-friendly. Flywheels store energy, the more mass, the more energy. They also dampen firing pulses. I ran one in a OT big-block car, and while the motor had more than adequate torque to overcome the lack of stored energy, the lack of damping quickly got old. Never had a car develop rattles so fast....
    Hnstray and Algoma56 like this.
  3. mgtstumpy
    mgtstumpy
    Looking at hogs head the lower bolt holes below the pan line are only used to secure an inspection cover. I'd trace the pattern onto some cardboard and fabricate a bolt up cover to fill the gap from some heavy gauge sheet metal.
    ottoman likes this.
  4. Dumb ass Q here......What is Hogshead? Is that/was a vendor? Is that the MFG of the part?
  5. The bellhousing is sometimes referred to as a hogs head.
  6. Here's a Model T hogshead, so named for the shape. Calling a modern bellhousing a hogshead is taking a little liberty with the term.
  7. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    You'll need the factory Chrysler starter plate # 1613713 or #1736183 seems to work too. Plate should be 1-1/8 thick. Pic of Transdapt NC-4 and Chrysler plate #1736183
  8. Learn something new here all the time! Thanks!
    But- when I call someone A$$HOLE, it usually means they are without description....:rolleyes:
    slayer likes this.
  9. sdluck
    sdluck
    Sprint cars don't have flywheels
    Sent from my SM-J737T using The H.A.M.B. mobile app
  10. And the point of this reply ^^^^^^ IS? Did I mention sprint cars, YOU, your previous postings? WTF?
    And your point, or response to this thread is?
  11. Probably replied to the wrong post.
    classiccarjack likes this.
  12. 46Chief
    46Chief
    Thanks man! That’s the info I was looking to confirm. Much appreciated.
  13. 46Chief
    46Chief
    This is a Flathead Ford Hogshead. Definitely not a Bellhousing lol. 727822A9-CDC6-47BD-9241-5F40247D870D.jpeg
    INVISIBLEKID and mgtstumpy like this.
