History Heterodox Gauges
Discussion in 'The Hokey Ass Message Board' started by Ned Ludd, Jul 9, 2020.
  1. Ned Ludd
    Ned Ludd
    Here's another sourcebook-type thread of ideas and inspirations. Weird gauges; the weirdest will probably be speedometers, but who knows? Vertical drums, horizontal drums, fixed needles, perpendicular needles, transparent-disc needles, ribbons, helical-pointer drums. What have you got?
  2. Ned Ludd
    Ned Ludd
    I'll start. Vertical helical-pointer drum speedometer on a Mercedes-Benz "Fintail", 1959-on:
    Early Saab speedometers worked on the same principle, but horizontal:
    This is what the rotating drum looks like:
    BMC ADO16 speedometers used a flexible ribbon, I believe:
    If this could come out of the rather utilitarian orientation of the European motor industry, I'm sure the far more flamboyant American industry will have more. Let's see some.
    AHotRod likes this.
  3. 7919E7B0-9CCF-4F40-8AAC-23FE8EA3B817.jpeg EB09A807-6F22-4BEF-9196-2CC2D8B0DAA1.jpeg
    66-69 Lincoln’s used this style it spun and lengthened almost like a thermometer
    Started out white and at 65 or so went red!
    I loved that car n all it’s little gimmicks and “luxury items”
    blowby and Ned Ludd like this.
  4. Paul
    Paul
    Editor
    Around 1960 Oldsmobile had them.
    I had a couple '62s that would show a horizontal line that would go green to about 35 then orange to about 65 then red till it buried at 120..
    VANDENPLAS likes this.
  5. Paul
    Paul
    Editor
    The vertical is cool, like a thermometer
  6. blowby
    blowby
    from Nicasio Ca
    This should be a fun thread, whatever heterodox means. I hate it when Ned uses those big words.
    Not much to add, except I noticed my recently acquired '56 Vette has an odometer in the tach. I asked ScottyT what the heck, 'cause the speedo already has one. He says it counts up the revs. Hmm, still don't quite get that.
    j hansen, Ned Ludd and VANDENPLAS like this.
  7. seb fontana
    seb fontana
    from ct
  8. What are the little lights indicating?
  9. seb fontana
    seb fontana
    from ct
    ""What are the little lights indicating?""
    All the usual stuff; headlites, high beam, park lights, acc, turn signal and some odd stuff, trans filter oil pump, line loc [in the shadow of the tach], fuel pump, reverse, oil filter [Oberg by pass] and I think one [at least] hasn't been assigned yet over the last 52 years. May be carb secondary opening candidate.:)
    Ned Ludd and fauj like this.
  10. Ned Ludd
    Ned Ludd
    1959 Buick:
    1961 Oldsmobile:
    Here's an Olds drum:
  11. j hansen
    j hansen
    Elcohaulic, hfh, VANDENPLAS and 2 others like this.
  12. j hansen
    j hansen
  13. Ned Ludd
    Ned Ludd
    The action was conventional enough, but the 1947-8 Nash speedometer had the numerals printed on the lens:
    Elcohaulic and VANDENPLAS like this.
  14. Ned Ludd
    Ned Ludd
    Many early speedometers used drums or discs behind fixed pointers, e.g. this '20s Packard:
    As, of course did the familiar '28-'29 Model A:
    Changed to a conical drum for '30-'31:
    Elcohaulic, VANDENPLAS and blowby like this.
  15. Paul
    Paul
    Editor
    Love that '20s Packard panel,
    everything you need to know right there.
  16. WB69
    WB69
    from Kansas
    The 59 Buick is almost hard to comprehend. Definitely has a lot going on there.
  17. birdman1
    birdman1
    Don't forget the 1957& 1958 Mercury's . It was 2 spools that wound the colored tape as speed increased.
    Ned Ludd likes this.
  18. birdman1
    birdman1
    Hour meter??
  19. Ned Ludd
    Ned Ludd
    Was that an actual ribbon or tape or a drum?
  20. 62SY4
    62SY4
    from Irwin, Pa
    '56-'58 Studebaker sedans had drum type speedometers, '56-'57 sedans also had color changing drum type indicators for the fuel level, amperage, coolant temperature and oil pressure. Sorry no pictures...
  21. the-rodster
    the-rodster
  22. e1956v
    e1956v
    Alliance Vendor
    Here is a 60 Buick mirror speedometer I repaired. Hey it could be considered the first heads up display. BUICK 1.jpeg BUICK 4.jpeg BUICK 6.jpeg BUICK 8.jpeg BUICK 9.jpeg BUICK 12.jpeg BUICK 14.jpeg BUICK 13.jpeg
    34 GAZ, RMR&C, GordonC and 3 others like this.
  23. Ned Ludd
    Ned Ludd
