heres a dumb question.....
Discussion in 'The Hokey Ass Message Board' started by NCrod, Apr 16, 2008.
  1. NCrod
    NCrod
    Wheres the fuse box on on a 54 chevy? Does it have one? This wiring is a mess and i need to get it sorted out! Thanks alot
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Not a dumb question
    there isnt one. Just individual electrical fuses on important power lines. there are inline fuses for the radio, heater , fuel gauge, and a few others i can't remember right now . But no usual fuse box or panel.
  3. The real cheap model did not. It was the same basic lay out as the tri 5 is. That includes the pick ups.
  4. raceratrod
    raceratrod
    Do your self a favor for the time spent and money buy a new wire harness. I had a rats nest wire harness on one of my cars and it was nothing but trouble every time it was driven. Lights worked when they wanted to and i had a short which almost burned the car up . The best money ever spent.
  5. beetlejuice55
    beetlejuice55
    a 54 chevy has no fuse box ???
    that's really weird, i've never heard that before.
    when did fuse boxes start becoming standard equipment ??
  6. 302GMC
    302GMC
    from Idaho
    Many '54s don't have one ... an accessory fuse panel was available for easier installation when more optional equipment was used.
  7. cretin
    cretin
    I had a few fuses on the firewall, underneath the dash on the driver side. But like raceratrod said you should buy a new one and rewire it.
  8. NCrod
    NCrod
    Any recomendations on what kind to buy?
  9. falconwagon62
    falconwagon62
    EZ Wire, 12 fuse, see them at swap meets/shows for 149-179 ez to install...has more than you'll need...John
  10. FiddyFour
    FiddyFour
    rebel wire makes a good harness... US made as well far as i know...
    Fat Hack was going to make wire harness' a couple years ago and sell em, dont know what all happened widdat tho
  11. rodknocker
    rodknocker
    I agree,get a rebel wiring harness,you'll spend less on that than the pieces and headache.PM glenn33 or check out his add in the classifieds, you'll be happy you did.
  12. glenn33
    glenn33
    from Browns, IL
    Sounds like a job for REBEL WIRE...ta da....
    If ya need any help sortin things out, let me know...
    Glenn
  13. FiddyFour
    FiddyFour
  14. 53sled
    53sled
    from KCMO
    I had to relearn everything I "knew" about cars with my 53. The wiring really threw me, as most of it runs of the gauge cluster and the voltage regulator. I'll probably rewire it when I swap moto- engines. :rolleyes:
  15. NCrod
    NCrod
    Its American made, and they're on the HAMB.....I want it! You got yourself a PM mr. !
