Technical Henry J gurus.. Radiator Questions...SBC
Discussion in 'The Hokey Ass Message Board' started by plodge55aqua, Apr 29, 2014.
  1. plodge55aqua
    plodge55aqua
    from Alberta
    What are you Henry J Builder/owners using for a Rad ? Sbc engine, Turbo 350 Trans. what cutting or mods did you have to do, without hacking up to much? Thanks ...
  2. bulletproof1
    bulletproof1
    from tulsa okla
    mine didnt have a core support ,so i made one out of tubing..custom radiator..
  3. plodge55aqua
    plodge55aqua
    from Alberta
  4. Hemi j
    Hemi j
    from Colorado
    I had a custom 4 core built for my blown Hemi
  5. blue 49
    blue 49
    from Iowa
    I haven't gotten to my radiator yet but I have a custom front stub and am working on a tilt front end so my options are wide open. I'm thinking about a '67 Chevelle SS 396 replacement one from Rock Auto.
    Blue
  6. Hooley
    Hooley
    I use an aluminum one for a stock car . Got it from Speedway Motors Race catalogue. It has cooled a big block and a blown small block with on issues. Oh yea its on Alky. It didn't have a core support so I built one.
    Hooley
  7. Beau
    Beau
    I have a radiator out of a '52 Henry J that had the flathead Supersonic engine. The radiator is VERY close to the 65/65 Mustang radiator I have in my Model A. I can get photos and measurements for you. If you have a stock radiator already, I have a thread with photos, measurements and info for the 65/66 Mustang radiator.
  8. bobwop
    bobwop
    from Arley, AL
    Speedway radiator with custom radiator support
  9. Beau
    Beau
    Both radiators have oil cooler hook ups.
    Spectra part #A1463 for Inline 6
    Depth -1.938
    Height- 16.313
    Width- 16.938
    1.25" inlet and outlet.
    Sprectra part #B130 for V8
    Depth -1.938
    Height- 16.313
    Width- 16.938
    1.5" Inlet, 1.75" outlet.
    The difference between the V8 and inline 6 is the 1.5" inlet and 1.75" outlet diameter. So the replacements for V8 and V6 are the same in dimension, but differ in outlet location and hose size.
    inline 6-
    V8-
    I can't find other info on the Henry J online. But the core size is close.
    Henry J
    Core 17x17
    Inlet Size 1-1/2"
    Outlet Size 1-1/2"
  10. plodge55aqua
    plodge55aqua
    from Alberta
    Thank you... the spectra looks like it might be the one...
  11. plodge55aqua
    plodge55aqua
    from Alberta
    If you wouldnt mind , that would be great... we have a very crappy bunch of stores up here... auto wreckers have nothing ..
  12. Beau
    Beau
    I'll measure the two tomorrow. Did your car have the four or six cylinder stock?
  13. plodge55aqua
    plodge55aqua
    from Alberta
    Hi.. The one I have, had the 4 cyl. engine.. I didnt want to cut the fire wall so the engine is on the a frame. Ill have to run a electric fan in front of the rad and move the center bar that holds up the hood latch area.. I may have to run a curved bar for support ..
  14. doinbad
    doinbad
    from celina tn
    i used a 65 mustang rad for a hi po 289 3 core, lower hose is on right side trimmed off the brackets made new one to hold it from top i run electric fan in front of it no cutting or modifying the support. cools my blown 283 great
  15. Beau
    Beau
    Yeah from what i see it will almost drop in. Both radiators I posted will work they're both three core. Just find the one with hoses that fit your application. Auto zone stocks them.
  16. plodge55aqua
    plodge55aqua
    from Alberta
    Thank you... Couldnt help but notice the writing on the Ruler..
