Henry J Done?
Discussion in 'The Hokey Ass Message Board' started by Von Hartmann, Sep 17, 2007.
  1. Von Hartmann
    Von Hartmann
    from Byron, IL
    Well, I've probably had the car on the road for about four weeks now. I just have been procrastinating this thread. I posted some pics on here before, but those were just mock up. For those of you who haven't seen it yet, it has a '68 chevelle 327 bored bored to a 331, Double hump 2.02 heads, high lift cam, 10/1 compression, holley 390's, large journal steel crank, and so on. The trans is a built th400 with a shift kit a hipster torque converter with a 3500 stahl. The rear is a 9 in. ford with a 3.89 posi nodular 3rd member and 31 spline moser axles. Front brakes are 67 volvo 122s discs on a 38 willys straight axle. Rear has stock disc brakes. steel tilt front. drag link steering set up. runs like a raped ape. Haven't run it at the strip yet, but I expect it to run low 12s, high 11s. The first pic was when it was stock the way I bought it.
  2. GrantH
    GrantH
  3. buckeye_01
    buckeye_01
    Looks great! Done? Are they ever really done? How about done enough to rack up some miles.
  4. GassersGarage
    GassersGarage
    That Henry is just tooooo Baaaaaaaaaaad! Hows she run with the crossram?
  5. Jet Doc
    Jet Doc
    Will it make an appearance at the Pile Up?
  6. FINKSTR
    FINKSTR
    Looks great. I was looking forward to checking it out at the Byron drag strip show but am glad you got the mechanical problem fixed. The shirt I got from you is killer.
  7. I love you henry j. You gotta bring it to the pile-up! I would ask for better engine shots, but bringing it to the pile-up will do.:D
  8. Kilroy
    Kilroy
    from Orange, Ca
    A gasser ain't 'done' till it's faster than your reflexes...
    Feel free to use that whenever you want. :) :)
  9. The lettering is the finishing touch. Looks like a ton of fun! Enjoy!:cool:
  10. 52 HenryJ
    52 HenryJ
    yet another reason to get mine done already!!! looks great man, How hard was it to set up that front end????
  11. Zettle Bros.
    Zettle Bros.
    Lookin' great Ryan. You introduce it to the Byron PD yet?
  12. Thumper
    Thumper
    Kickass !! Dead on.
  13. paco
    paco
    from Atlanta
    I've been a HJ fan since I was in HS......you've done this one "right".
    Paco
  14. ryangobie
    ryangobie
    from Jersey
  15. Von Hartmann
    Von Hartmann
    from Byron, IL
    Yes it will be at the pile-up. And the front end wasn't too tricky to set up. I used the original stub and hung the axle on a milk crate with tie wire. It worked. He rides great and doesn't pull, and that's just alighning the front end with a tape measure. I haven't really showed it to the PD, Zettle Bros. But I also haven't been pulled over yet. I have a friend that knows most of the cops. I'm sure that helps
  16. dragrcr50
    dragrcr50
    koooool as hell man I want it..............
  17. 51 Hemi J
    51 Hemi J
    Looks great! I haven't even started on my J yet, but have a good "pile-o-parts" going.
  18. Hell Focking yeah! That is focking awesome!!!
  19. jangleguy
    jangleguy
    Looks killer! Congrats. Glad you're driving it. Please post drag results asap...
  20. Looks Great!!!
  21. ....that Henry's got such a pull off the line that one of the vent window glasses fell out !!! ...time for some colored plexi-glass.
    Kool Henry Ryan.....lookin forward to seein you guys at the Pileup.
    ...can't wait.
