HEMI Tech- Identification
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 17, 2006.
  1. Niksramjet
    Niksramjet
    Will do, Sorry for the confusion. Just trying to get the widest dissemination.
    Thanks.
  2. monc440
    monc440
    Hi Guy's going to look at a Hemi today. The block casting shows 1619829 for 354 and the stamp has an M for marine however is is stamped M35 4-2020. Any ideas? The only reference I can find for marine are all M45-- The head casting number is also 354 but no water outlets, I thought that was only 331 heads? Please see pics below.
  3. George
    George
    The Marine, Industrial & truck engines are like the 51-54 car engines, heads, oil pan, ect. What intake? tuck & marine are different from each other & from car intakes.
  4. monc440
    monc440
    Thanks George
    The engine doesn't come with an intake. Everything is disassembled and I believe it is a mix and match of parts. It comes with the block, crank, rods, pistons, 2 sets of heads, 2 transmission adapters. When I go look at it I'm going to get casting numbers off everything to see what I'd be in for if I buy it.
  5. 73RR
    73RR
    No real mystery. The photo showing the end of the cylinder head clearly shows the truck 'pad'. If you remove the spacer gizmo on the intake rail you should find the tall water passage at the center where pass car heads have exhaust passage. The 'spacer' on the front is typical of the truck water pump being raised up a wee bit to get the fan higher.
    30dodgeboy likes this.
  6. George
    George
    Why would a 354 block need a spacer?
  7. gimpyshotrods
    gimpyshotrods
    Someone was probably making a manifold.
  8. DAHEMIKOTA
    DAHEMIKOTA
    from Tenn
    Being an industrial engine it may have gears for the cam timing instead of a chain.
  9. mgtstumpy
    mgtstumpy
    My contribution, others with more knowledge can clarify. Hemi ID.jpg hemi-engine-block.jpg
    town sedan likes this.
  10. 73RR
    73RR
    Agreed, likely a u-fab project.
    Trucks usually had gears but nothing shows in the pics and a pass-car cam is the usual cam used.
  11. gimpyshotrods
    gimpyshotrods
    Make sure there is a car/truck/industrial crank in that mix.
    Dedicated marine cranks are ever so slightly different, necessating a trip to a crankshaft shop, to fix it.
    On a land going vehicle, there is a slight step in the snout for the timing chain sprocket. It is not there on a dedicated marine crank.
    They run their drive on the "front", and all accessories are gear-driven.
    A good crank shop can make the step "appear" there.
  12. scootermcrad
    scootermcrad
