HEMI Tech - Engine and Component Dimensions
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 8, 2011.
  1. scootermcrad
    scootermcrad
    Okay, for some reason I've received several emails and PM's lately on Hemi dimensions and unfortunately I have virtually NOTHING in the way of drawings and diagrams. Been meaning to do some for a long time, but haven't had time to do them.
    SO! I'm starting a thread that can serve as a location to put all early Chrysler, DeSoto, and Dodge Hemi measurements, diagrams, and whatever else you have that will be helpful. Very little out there. I will be adding this to the HEMI Tech Index.
    Post up dimensioned drawings of:
    - blocks
    - engine assemblies
    - transmission and/or bell housing mounting patterns
    - component dimension (i.e. oil pump mounting flange differences, water pumps, etc.)
    - mounting ear locations
    - overall engine dimensions
    or anything else that would help with installation, chassis design and construction, fitment, identification, etc., etc. If you guys aren't sure how to post pictures, can't post pictures, or are simply someone that lurks but doesn't post, you may PM me the info or I can give you my email and I will post them for you.
    NOTE: As always, lets keep this limited to first generation Mopar Hemi and Poly engines. Daimler Hemi dimensions are welcome as well!
  2. scootermcrad
    scootermcrad
    So this has been added to the tech index...
    Anyone have anything that would like to add?
  3. Stefan T
    Stefan T
    from Sweden
  4. BashingTin
    BashingTin
    Both of them open fine for me. Any basic cad software that opens the .dxf file extension should be fine.
    I don't use Windows, but Linux. The tool I use to look at them is called QCad. It's free and very simple. I've been using it for years now, and I really like it. It doesn't have any where near the features of a real cad system like AutoCad or Solid Designer, but it does what I need. I'm sure there are free simple cad softwares out there that run on Windows and Mac. You should also be able to find and install a free .dxf viewer too.
    I hope that helped.
    David
  5. ghostworks
    ghostworks
    question can i stuff my 331 chrysler hemi heads on a 64 318 poly block?
  6. scootermcrad
    scootermcrad
    Keep the info coming guys. Some posted JPEG files would probably a better format for some.
    Not the place for this question. And the answer is also no. Please check out the HEMI Tech section we've put together or do a search. This has been discussed many times.
  7. 73RR
    73RR
    Scott, it is too bad that folks won't go back and delete posts that they put in obviously incorrect threads, and in this case, a duplicate from another thread!
    I had hoped that this thread might actually stay 'clean'...:cool:
    Now, back to our regularily scheduled programme...
    Here is the back of the EarlyHemi / pre-62 A series. (Not the 51-53 331...)
    ....on the count of 3, everyone go make their own adapters....
  8. Just contributing to the thread. I have asked Q's,gotten excellent info-(Thank You) and trying to "give back".
    Here goes......
    My 58' 354 Chrysler block- From rear face to front face= 21 3/4
    Water pump housing with stock pump and pulley= 8 1/4
    Rear sump oil pan =8 1/4 deepest.
    Stock crank pulley =3 1/8 depth
    Pics might be deceiving......
    Last pic is what dreams are for:D
    Hope this helps-Kid
  9. scootermcrad
    scootermcrad
    Good stuff guys! Keep it going!
    And I agree, Gary. I was hoping we could keep this one "much free" as well.
    I'll grab my camera this afternoon and work on some extended bell 331 dimensions. I also have a 354 water pump sitting here that I could get some dimensions off of.
  10. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Quote: Here is the back of the EarlyHemi / pre-62 A series. (Not the 51-53 331...)
    My exact thoughts. But only after they email you and want to know the thicknesses, etc. :)
  11. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    Ind 24a 331 ( 354 same)
    bighemifan and Just Gary like this.
  12. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    IND 20A Extended block
    bighemifan likes this.
  13. scootermcrad
    scootermcrad
    Well... I was literally about to go take some measurements on one of the extended bell, but it looks like that will not be needed. HAHA! Now THAT is some detailed dimensioning!
    THANKS!!!
  14. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    241
  15. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    low deck desoto
  16. Nuvolari
    Nuvolari
    from Italy
    you can have a design in this way. dxf of a hemi 354 of 1956?
  17. gatz
    gatz
    Is the hole/bolt pattern for a '54 331 available?
    Looks like it would be similar to the drawing posted, but on the 331W that I have, the bottom of the block is at the crank centerline.
  18. 73RR
    73RR
    Look a bit closer...the dimensions are off of crank centerline.
    Hnstray likes this.
  19. gatz
    gatz
    is this drawing correct for a 331 then?
  20. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    If you look at your block again, you will see that the main caps are recessed in the block. The centerline of the crank is not even with the surface of the block.
  21. gatz
    gatz
    ok
    my mistake...I see now that the rear main is set down into the block
  22. bostonhemi
    bostonhemi
    Very helpfull thread. TY
  23. Von MoPar
    Von MoPar
    from Australia
    Fantastic, any chance of a 315/325 hi deck dodge blue print
  24. hemiphil
    hemiphil
    from australia
    need to know center line distance crank to cam early hemi, thank you.
  25. BashingTin
    BashingTin
    6.125"
  26. hemiphil
    hemiphil
    from australia
    thank for your info, cheers, i will have to catch up with you next time i am in denver should be around this time next year after the 60th us nationals
  27. 340 Power
    340 Power
    from NW PA
    Very informative thread.
  28. Good stuff. Thanks.
  29. town sedan
    town sedan
    Came across this old but good thread the other night and wanted to bump this to share the "blue prints" TR Waters posted way back when. Good information shouldn't gather dust.
    -Dave
  30. Anyone have tall deck 330 Desoto, or is the low deck close?
