HEMI Tech: Camshafts.. new? Regrind? solid or Hydraulic?
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jun 26, 2006.
  1. 73RR
    73RR
    Sadly, the clockable starter does not help. The only way to make a 904 work would be to rotate the trans on the adapter CCW to drop the starter position.
    Also, recall that the OD is 0.69:1 so a 4.56 becomes 3.14 or so.... your 3.55 looks like a 2.45.
    Now, what's more fun than a TF and 4.56? :D:D
    loudbang and falcongeorge like this.
  2. Arominus
    Arominus
    That's a shame, I really liked the idea of the lighter 904, less power use, less weight, wide ratio spread, it was ideal in a lot of ways for the build. Its a shame there are no ready made plates out there already, i'm not so hot on commissioning a custom one as a have QEP half adapter ring already hanging on the pegboard at home (had it for years now).
  3. Does anyone have a good suggestion for having a roller cam reground? I have a NOS Sig Erson cast roller cam that is too much cam for my combination. I currently have a Isky solid flat rapper cam and want to upgrade. 11218.jpeg 11220.jpeg
  4. Yes - talk to the guys at Bullet Cams - they've made a lot of different cams for all sorts of street and comp engines that I've been involved with (and a ton of full competition late 426 style blown-alky Hemis and everything else imaginable).
    BTW, I would not attempt a regrind on your cast iron core - as with the spring pressures we need/run today, you should have a heat-treated steel 8620 core. Bullet can supply the steel core - not a problem.
    Here are the specs and part number that they used to grind a cam for a blown 392 Hemi. I've not ran the cam yet - other projects are in front of it!
    Grind No: CROH 277/282-12R
    Specifications: Intake Exhaust
    Duration at .050 248 253
    Duration at .020 277 282
    Lobe Lift .360 .3615
    Separation 112
    Timing Events at .050 16 – 52 62.5 – 10.5
    Gross Valve Lift .540 .542
    Valve Last Hot .010 .010
    Degree Intake Lobe to 108
    This cam requires springs with about 190 lbs @ 1.950 installed height (seat pressure), With 552 lbs @ 1.250 (max lift). Given that the cam above only lifts .540, the spring pressure will be a lot less at full open.
    Give them a ring . . .
    Bullet Racing Cams
    bulletcams.com
    8785 Old Craft Rd, Olive Branch, MS 38654
    (662) 893-5670
  5. Thanks for the reference. I should have been more spacafic on my request. I have a street strip combo 392 Hemi, naturally aspirated with a 4.4 stroke crank, 10-1 compression. The car has a torqueflite with a 3k stall, 4.10 gears and weighs 2800 pounds. I don't want to put long valves and offset rocker stands.
  6. hemihotrod66
    hemihotrod66
  7. 73RR
    73RR
    Since you want to avoid long valves and stand work you should keep the lift at 0.500 max. I have used 0.515 a couple of times but found that there is alot of scuffing between rocker tip and valve tip. Offset stands are helpful even without long valves if you are at the 500 mark.
    As for the roller regrind, call Schneider and talk with Jerry. I agree that 280@050 is a bit steep. Perhaps 240 would have better manners...;) and be a little easier on valve train parts.
    racer-x likes this.
  8. Excellent! Thanks for the info.
    I still have a reground long nose 331 cam you did in back in the nineties. That engine never got done as the 392 took priority.
  9. gimpyshotrods
    gimpyshotrods
    I'm right at 0.500" lift.
    Who makes good offset stands?
  10. alphabet soup
    alphabet soup
    I second Jim at Racer Brown. But I may be a little biased, as he is a good friend of mine. I have used plenty of his stuff in everything from a 283 boat engine to a 440 drag car and a few things in between. I haven't run the motor yet, but I have a 210* regrind in a 153 4 banger I'm building. I know he has done many fresh and regrinds for the early Hemis and even early flat head stuff, but I have not used one in any of those yet. Gene.
    And Mr. 32 is correct 410-866-7660 after 2pm eastern.
  11. 73RR
    73RR
    Call Gary Patrick at 530-242-1316
    He has my full faith and support.
  12. gimpyshotrods
    gimpyshotrods
    Ha! That's who rebuilt my rocker arm assemblies!
    For everyone else, that's Rocker Arms Unlimited!
    My stuff came out stellar, and the turnaround was alarmingly fast!
    http://www.rockerarms.com/
    73RR likes this.
