Hello; Have the following for you consideration. All parts are in US dollars plus shipping. Cash, POSTAL money order or Paypal. Any additional info you need just give a shout. We will pack item well and help you find best means to ship. Selling whats left of all my Hemi stuff. LZkustomkraft at gmail.com (replace at with @) phone 585-545-069zero. Best to call after 5 PM EST. Do not have voicemail. Thank you. Have a Merry Christmas or whatever it is you practice. Enderle Stack injection. 2 7/16". No port work, bolts holes clean. With original Barrel valve and lines (no nozzles) There is some dings and a small slit in a couple stacks. It is a real nice injector. $1175. 331 block #1551629 with Arias Pistons. Its been line honed, decked and bored -honed .060 over, with New matched Arias Pistons, pins, rings, Great start to your project. $1475 331Crank #1409421 Ground 10 and 10 EC, Flywheel holes tapped. $325 Super deal Take above Block, Arias kit, Crank all for $ 1675 Valve covers Hemi Firepower, VGC, $120 Donovan 417 "wet heads" $ 475 with a few Titanium valves. 392 Brand New, Comp Billet Roller cam Brand New, see photo of Cam card. $275 Set of Milodon Valves in EC (missing one exhaust valve) $100 Titan Roller rockers included with the Valve cover spacers kit, plug tubes also including the pushrods and head studs from engine this came from. These can be set up with oiling bar to prevent pulling valve covers each run. little run time , a deal all for $1750 ARP head studs(missing nuts) and pushrods from engine that had above rockers. $75 Following came from a 354 Industrial. Everything for $ 75 - Oil Pan, Pump and pressure line for gauge. - Pulleys, Bracket, spacer, damper bolt, - Valley cover and Timing cover. - Cam and Intermediate (pump) drive - Water pump and 3 starters one a weber ultratorx - Spark plug tubes. Various fasteners and Pcs. Odds and ends: - New intermediate shaft $45 - Yellow Ceramic plug side, wire ends. $35 - Mallory Mag base, EC, Shaft measures 4 1/8 mounting interface to end. $75 Thank you
Good day HAMB'rs Updated list . Will attach new updated photo link soon. Just contact me with any info you need or more photos. Thank you Luke
