I have a 12v chrysler generator. It has the tag on it, so if needed, I can get that number. There are two posts on the generator. One of the posts is slightly thicker than the other. I don't see any labels on the generator. Which one is Field and Arm? Do I need to run a ground from the generator?
Armature post is the big one, field the smaller one. Hope this helps. A ground from the generator to the base of the regulator is a good idea.
