Hot Rods Helped my pal fix a charging issue on his rot box coupe
Discussion in 'The Hokey Ass Message Board' started by Pete, Aug 11, 2021.
  1. Pete
    Pete
    Chuck called a few weeks ago, said his car was acting funny. Said it would crank hard after he drove it...like the battery was discharging....new battery, new voltage regulator....
    So I took a trip over and tested a few things. Bypassed the voltage regulator, checked the raw output of the generator...it’s a 6V... output was 9-10 volts on the multi meter. Than we checked the voltage regulator, it too was charging the battery??? I notice there was no ground on the generator stud, so we added a ground wire from the stud to the base of the voltage regulator. Seems to be fine now,,,these old “rot rods” need good grounds,,,electricity is a funny thing.
    pics,,,,some may recognize the car from the “hot rod magazine” thread
    amazingly solid car for 88 years old, perfect amount of sun burn, rashes and the original Ford paint. This is a lifelong California car that’s been in Massachusetts for like 10 ish years now,,Chuck drives the F$@k out of it.
    3E7A6C7E-59FB-4977-81B1-271E3D9CF80E.jpeg 4F51C7F7-142C-45A7-841F-78259D5BFFA7.jpeg 82E88D0A-4425-4466-A003-5A5E9B7B76FC.jpeg 988B147D-6D42-4A1D-AFF1-A764CD73F1A6.jpeg 9ADEBB5A-4040-42C8-85CF-AC8A388058F1.jpeg 015C0FFE-9E8B-4D4D-AED5-D46202B72E1B.jpeg 41F82F97-56E1-4ED1-B881-664FCEB17B12.jpeg 1DC9CE6E-26FE-4DD9-91E1-0BDECC51573D.jpeg 0FA2942A-03CF-4133-9415-623DF0E06189.jpeg 7DBF0C28-CFDF-4FFB-82DF-806D3BF03429.jpeg
  2. Mr48chev
    From the looks of the car I'd have to think that there enough corrosion on the engine and bolt on items that it was probably the issue. I've seen it both ways, too much corrosion or too much paint keeping things from making ideal ground contacts or ideal electrical contact all together.
    loudbang and VANDENPLAS like this.
  3. Budget36
    Budget36
    I might be wrong, and normally am, but doesn’t a generator put out like 30 volts ?
    seb fontana likes this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    6 volt generators put out a max of 6.9 volts.
    I’d give my left nut for that crusty old Ford.
    loudbang, wheeldog57 and VANDENPLAS like this.
  5. oldiron 440
    oldiron 440
    I'd like to see someone up that bid...
    Petejoe, loudbang and VANDENPLAS like this.
  6. I’m married with kids I’ll give the twig and the berries….. :D
  7. Pete
    Pete
    VANDENPLAS likes this.
  8. lostone
    lostone
    from kansas
    He wins !!!
  9. Budget36
    Budget36
    Even with the regulator disconnected?
    Oh, keep ya nut(s);)
    Petejoe likes this.
