I wonder if someone could/would tell me about the backup light switch wiring to/from a T-5 Borg Warner tranny please? I have one from a '91 S-10 but did not get the wiring harness etc. I need specifics on how to connect the tranny to my wiring. Thanks in advance. Perley
I can check tomorrow at work. We have an alldata system that has wiring diagrams.. I tried to do a little searching for you on the web, but my search (computer) skill's are a bit sub par.....in other words, i suck. Simple question, is it a standard type two wire switch? If so, it should be a simple power in one side, back up light feed the other.. Tony
Simple question, is it a standard type two wire switch? If so, it should be a simple power in one side, back up light feed the other.. Tony[/QUOTE] Yes it is,
haaahaaaaa DUUHHHH. Feel like a dummy, ME. If I hadda looked I woulda seen, yep, two poles on plug. So, guess I can figure that out, huh Tony. Many thanks. Perley
