help with these motor mounts. sbc
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Jan 2, 2012.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
  2. Go to your favorite parts store and tell them you want motor mounts for a 1968 Camaro with a 327. Left and right are the same.
    $8 - 12 each depending on where you shop.
  3. 29moonshine
    29moonshine
    chevelle or nova v8 64-67
  4. poncho62
    poncho62
    I believe the Speedway ones shown are early 60s....by the late 60s, they had the overlapping steel pieces in case of failure of the rubber. In 73, they changed to the clamshell engine mount
  5. Energy suspension catalog says 2 styles of motor mount. Short and wide:2 5/8 inches at the frame saddle by 1 3/4 tall. Or, tall and narrow:2 3/8 inches at the frame saddle by 2 3/16 tall. They both are sbc on the block side of the mounts. About $50. each.
  6. squirrel
    They're a fancy aftermarket replacement for a stock Chevy mount
  7. Thats what I did.
    Terry
  8. DICK SPADARO
    DICK SPADARO
    The engine mount in question are stock Chevy style engine mounts pre 68. Probably due to some Gov ruling to prevent engines from being dislodged during accidents the engine had to be locked to the frame mount and the design changed to the later design in post #2 which is bigger and bulkier looking
  9. hot rod pro
    hot rod pro
    from spring tx.
  10. Mr48chev
    Yep, those are the clean ones but they do break after a while especially if the car is driven hard and that is why they started putting the catch hook on them that always gets in the way of what you are trying to do.
    Having the left one break at wot can be a thrill ride until you get the rig shut down.
    with anti lift hook. http://www.autozone.com/autozone/parts/1958-Chevrolet-Impala/Motor-Mount/_/N-j2bbyZ93xoa
  11. yEP GET EM AT A PARTS STORE NEAR YOU THAT WAY YOU CAN PREVENT THE MISTAKE OF GETTING THE WRONG ONE OF THIS TYPE MOUNTS.....THERE IS A THICK AND THIN VERSION,,,,,EARLY 70S WERE ALMOST AN INCH TALLER ]SORRY= CAPS[
  12. squirrel
    along with thick and thin, there are different widths across the two holes that fit on the frame bracket. And the various interlocking permutations, and then there's the truck mount with the single threaded hole in the middle, etc. And the slightly different mount for 58-62 cars with the six.
    But no, Chevy never used polyurethane mounts like that.
