HELP !! I HAVE A 1954 chevy pickup, I'M trying to find out for sure what year motor I HAVE!! I'VE ORDERED 3DIFFERENT WATER PUMPS NONE FIT!!! THE PULLEY IS PRESSED ON THE SHAFT. IT SHOULD BE A 235 ?? THE NUMBERS BEHIND THE DIST. ARE AS FOLLOWS--- F1012A FOLLOWED BY JH780108, ANY HELP WOULD BE GREATLY APPRECIATED!!!
Why don't they fit? Are they totally different in how they bolt to the block? No factory pumps had a pressed pulley after '54. There are three variations of early style pumps--'37-'40, '41-'52 (wide pulley for 1/2 inch belt), and '53-'54 (narrow pulley for 3/8 inch belt). The '55-'62 pumps are longer, use a bolt on pulley, and have a visible impeller, as opposed to the early pumps that have a flat steel plate screwed to the rear of the pump that covers the impeller.
I'm pretty sure that JH780108 serial number identifies it as a 1951 engine. That's the only year engine numbers began with a J. It'll be a 216 unless it came from a one-ton or larger truck, which would have a 235.
http://groups.msn.com/STRICTLYCHEVR...Message=2783&LastModified=4675659095918175216 and http://www.msnusers.com/STRICTLYCHEVROLET/msgattachments/173 these numbers here dont metion j or h, nearly all start with 3 car motors?
The 2 pumps i ordered came in and had 5 bolt hole, the other one with the pressed on pulley was the wrong bolt pattern
water pumps and smog pumps rebuilt by a master rebuilder with over 40 years exp all makes from A-Z 1900-2000 porsche, mercedes benz, maserati,ferrari, cadillac, ford, chevy, john deere,perkins, packard, rolls royce, studebaker,rover,jaguar,ALL industrial pumps, Marine,Farm,buick,BMW,amc and so on if you want it rebuilt by the master, we will handle your pump one on one with the best care from start to finish with the highest quality parts and labor NOTE we do have kits available for the do it your self guys, we can find original cores and special date codes and so on note dont be fooled by the middle man buy direct from the best, AUTO-PAC 12523 limonite ave ste# 440-209 mira loma ca 91752 951-790-1310 email [email protected] 951-790-1310, [email protected]
The pumpon the truck now has 4 bolt patter, the lower left bolt is behind the pulley, i don't see how this one can be loosened without damage to the pulley itself!
The illustrations on rockauto.com show the '54 and earlier six-cylinder water pumps to have a four-bolt pattern with the upper bolts spaced slightly above the lower bolts and spread wider than the lower bolts. Additionally, the impeller is enclosed. Apparently there was a design change with the '55 235. Its water pump shows to still have a four bolt pattern, but the bolts are spaced equally around a round boss. The impeller is exposed. I've attached a photo example of a '51 216 engine number.
