help with flathead ford motor
Discussion in 'The Hokey Ass Message Board' started by rlcowboy40, Dec 14, 2007.
  1. rlcowboy40
    rlcowboy40
    from mass.
    can i run 1946 59ab heads on a later 8ba flathead motor without problems ,if so what year head gaskets do i use thanks----rick
  2. Capitan Insano
    Capitan Insano
    Its easy all you do is pipe plug one hole on each side and use the early gaskets
  3. Flat Ernie
    Flat Ernie
    Tech Editor
  4. mushmouth
    mushmouth
    from Minnesota
    The heads will interchange but there is a concern about some water passages. There are books available that mention the necessary mods. I believe you will want to use the gaskets for the particular heads. The water passages in question will need to be plugged. The Bishop/Tardel book mentions it and thats the one that comes to mind anyway and I'm sure others do also. I hope that helps.
