Technical Help with F-1 Brake conversion
Discussion in 'Traditional Hot Rods' started by dugydog, Jun 20, 2020.
  1. dugydog
    dugydog
    So I decided to go with F-1 bendix style brakes for the front of my 35 Ford. I purchased Curt Bakers book to guide me. I found an old 1950ish F-1 truck and removed everything I needed. I figured I’d go with new drums so I ordered a set of NAPA 4401070 drums ( according to the book) The installation was going real smooth, with new pads, bearings and races etc. until I opened the box of drums and tried to mount one onto the hub and realized it doesn’t fit. It’s not deep enough to cover the brake shoes. Anybody know what kind of drums I need? I’ve attached photo of old drum and new drum. Thanks for any advice IMG_4467.JPG
  2. 67L36Driver
    67L36Driver
    Can the old F1 drums be reconditioned/turned?
    Use them.
    The new drum above looks like ‘53-‘56.
    BWTFDIK
  3. Mr48chev
  4. dugydog
    dugydog
    Well I just got back from my local NAPA store and found that the 440-1070 drums only fit 53-56 f100, he found the correct drums for 48-52 to be 440-1073. Hopefully this helps anybody who read Curt Baker’s “The Traditional Brake Handbook” and had the same problem. Thanks for help fellas!
    ABONES and 67L36Driver like this.
  5. 440-1073 is a rear drum I believe
    67L36Driver likes this.
  6. dugydog
    dugydog
    Oh man, well the NAPA guy ordered it so I’ll find out next Tuesday if it fits
  7. Mr48chev
    440-1073 is indeed the rear drum. I found that when I was doing the search earlier as dugydog did.
    Sent from my VS988 using The H.A.M.B. mobile app
  8. Your finding out why most go with the F100 (53-56) setup. Brakes the same (and backing plates) but the hubs are different. If you can't find a drum to fit you can always find some F100 hubs or good used F1 drums.
  9. Mac Van Pelt has new drums that will work
