Help with a licence plate frame.
Discussion in 'The Hokey Ass Message Board' started by Hot Turkey, Mar 29, 2010.
  1. Hot Turkey
    Hot Turkey
    I'm looking for a frame for my plate, it's a Florida 1932 plate 5 x 12. The plate has a warp to it and the frame would make it look much better. Thanks guys.
    David
  2. 40LUV
    40LUV
    from Mid Jersey
    Bob Drake makes an adjustable frame. That should work.
  3. fxfxr
    fxfxr
    from eureka, ca
    Try looking at "adjustable" frames. They slide out to fit most plates.
  4. Just put together a plate frame for a Virginia plate. Used aluminum picture frame components from the "Ben Franklin" (re: craft store) They come in pre-cut lengths, from 5"-20-some" and have clips with set screws @ the corners. The aluminum is brushed on the edges, but polished on the face. It worked out great for me.
  5. hotrod mike
    hotrod mike
    I've been looking for one for my 39 tag also. Same size. I'll let you know if I find anything. Mike
  6. Hot Turkey
    Hot Turkey
    Thanks guys, I hope to find a stainless steel frame.
  7. hotrod mike
    hotrod mike
    Seems like the Florida plates are sort of a bastard size. :mad: I'll keep lookin'.
