Projects Help with 55 Buick steering knuckle
Discussion in 'The Hokey Ass Message Board' started by slylark, Mar 12, 2016.
  1. slylark
    slylark
    Rebuilding front suspension on my 55 Century. Lower steering knuckle bushing needs replacing but I can't remove it from the knuckle. I torched/iced to break it loose, no luck. Used my impact, no luck. Any suggestions?
    When I took the knuckle off, the lower outer shaft was worn really badly. New outer shaft in old bushing has a huge amount of play. 1457823000677.jpg [/IMG][/IMG]
    Sent from my HTC One using H.A.M.B. mobile app
  2. BJR
    BJR
    Have you tried turning it the other way, maybe left hand threads?
    Hnstray and Fender1325 like this.
  3. Jalopy Joker
    Jalopy Joker
  4. Fr. Buick
    Fr. Buick
    You need a bigger wrench, it will come out. Lefty-loosey, nothing fancy here.
    Be sure it goes back in to the correct torque. See your factory service manual. I had a factory-installed one wobble out and ruin the larger part.
    I may have good used ones if you need it...
    If you are in SoCal, I have parts...
