Help wiring a starter button with a points ignition.
Discussion in 'The Hokey Ass Message Board' started by Hellbentrodder, Feb 11, 2013.
  1. Hellbentrodder
    Hellbentrodder
    from Cotati
    I admit I suck with the search feature but I honestly tried. What I need help with is wiring a start button with a points ignition. Does someone have a diagram or can at least tell me how. I am not sure where to put the ballast resistor if there is really no "run" position. I think it would go between the keyed on/off switch and the positive but am not sure. Thanks for the help.
  2. fsae0607
    fsae0607
    Is this for a GM application? The "start button" should be wired between a constant 12V+ source and the starter solenoid's "S" terminal.
  3. fsae0607
    fsae0607
    Oh and this too:
    http://www.jalopyjournal.com/forum/showthread.php?t=305205
    The diagram in post #2 shows how. Just ignore the purple "hot in start" circuit on the left. That's where your "button" will go.
    The yellow wire will go to the solenoid's "R" terminal.
    Again I assume it is a GM application.
  4. Hellbentrodder
    Hellbentrodder
    from Cotati
    Yes it's a 327. I got that the button goes between 12V and the "s". But where does the ballast resistor go to drop the voltage once its running?
  5. fsae0607
    fsae0607
    It goes between your ignition key switch terminal that is hot when your key is in the "RUN/ON" position and the "+" terminal on your coil.
    The yellow wire going to the solenoid's "R" terminal is only hot when you are cranking the engine, so the coil gets a full 12V for a hot spark to start a cold engine.
  6. Okatoma cruiser
    Okatoma cruiser
    from Ms
    On the positive side of the coil but. Some coils have a built in resistor
  7. skidro69
    skidro69
    from Dothan, AL
    I have a resistor on mine and don't use the full 12v for starting. Just the resistor on + side of the coil.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sorry, didn't catch the 327 SBC earlier for some reason.
    Power Push Button with Hot or On position from ign switch to S terminal
    Ing terminal from ign switch to ballast to + on coil
    R terminal from stater to the + on coil will be your resistor by pass.
  9. Hellbentrodder
    Hellbentrodder
    from Cotati
    Thanks for the help guys.
  10. fsae0607
    fsae0607
    No problem. Good luck! :cool:
