I'm putting a granada ford rear in my 40 cpe and want to replace the stock fitting(junction w/lines to each wheel) that includes about a 12" rubber line with a replacement fitting that hopefully has a longer rubber line. Anybody got a part number and or know how long a rubber hose portion is available? All help is greatly appreciated. Al PS no jokes please about having a short hose!
AL, <DD class=tel>(757) 224-1828 is a start with B and B hose near you. Just give them the length you need and they will make one up for you. This is an easy one and you can order on line from many folks.</DD><DD class=tel>regards,</DD><DD class=tel>George</DD><DD class=tel> </DD>
I went to NAPA and asked if I could look through their brake hose book. Found what I needed in about 5 minutes.
I,m using a 81 Granada replacment hose,you get the block for the lines and hose in one piece.You will have to file and turn it some and weild a piece to the frame to hold it. Works for me. George
Take the old hose to the hose guya nd he might be able to use the block end and save you a couple of bucks.
Take your short hose to a shop that makes hydro hoses..... should be under $10 for them to make a new longer one....
Most of the NAPA stores carry pre made hoses now just measure the thing and get one. The local NAPA here also makes Hyd,AC.Power steering and brake hoses and are reasonable on the wallet to.
Thanks for the help. I failed to point out that the hose and junction fitting is one piece so replacing the hose ain't an option from what I can tell. I expect to have to make up a bracket to hold the end of the hose that connects to the chassis and that won't be a problem. I just want more than 12 inches of brake hose in the one piece part that fits over the vent tube and attaches to the brake line coming from each wheel. I go see the Napa fellas... they're pretty good. I'll report back what I find so we can all write the part number on the wall! Reinventing the dang wheel (or brake hose junction) shouldn't be required so often. That is the main reason I have taken to keeping spreadsheets with part numbers, prices, and application for each car or truck I build or rebuild. BTW, I put the newly built driveshaft in my hemi powered 40 cpe using the new 5 spd today. I hope to get enough wires on it this weekend to get it running again but it may take longer as I may to fab a battery box to put the battery under the RF fender like I did on my chopped 40 pkp.... another opportunity! Thanks again. Start writing those part numbers on the wall in a legible handwriting! I realized I hadn't bought one before and I probably should have. One I find a magic solution, I think I'll buy 3 or 4 and start doing some PM on my street rod fleet. Al
