Technical Help to properly remove these..
Discussion in 'The Hokey Ass Message Board' started by chevnut, Mar 23, 2014.
  1. chevnut
    chevnut
    from Corona, Ca
    1953 Chevy 150 Sedan windshield wiper motor trim clamp thingamajig. thank you.
  2. Best way is to make a tool. Get a piece of pipe the same size as the retaining nut (the circle with slots) grind or saw through from 2 sides leaving tabs to fit the slots. Nice clean cuts and snug fit will do it. You will have the tool to reinstall and not mess up the nut.
  3. Dizzie
    Dizzie
    I have used a very small screwdriver and a hammer and "gently" tap in one of the slots to unscrew. Worked for me.
  4. chevnut
    chevnut
    from Corona, Ca
    thank you. I believe I have a tool I can use for it now. cheers!
  5. COUPES
    COUPES
    from England
    Used a bicycle spanner with dimples on it to get a friends out.
  6. squirrel
    for sure. I did that, it works great.
  7. Dave Mc
    Dave Mc
    The proper name for the thiggamujigg is a " BURR " or so G.M. named it in the Service Manual
  8. The tool is called a windshield wiper escutcheon bezel nut wrench. You can buy one, but as others have said, it's pretty easy to make one out of a piece of tubing.
    They look like this:
  9. chevnut
    chevnut
    from Corona, Ca
    :) thanks
  10. R Pope
    R Pope
    I make them out of the right diameter socket wrench, on a grinder.
  11. kustomclassics
    kustomclassics
    I've used a set of needle nose pliers just have to be careful.
  12. xpletiv
    xpletiv
    from chiburbs
    90° ring nose pliers may work, also.
  13. 28TUDOR
    28TUDOR
    Same here, I have also use a set of small 45* needle nose pliers.
