I need to ID these for future reference if possible. The bulb is 6-1/2". The OD is 7-1/2". The length is 7" w/o bulb. Part # on the bulb is 4030, not one I have heard of before. Thanks for the help!!!
If it helps, I don't think they're BLC or Guide headlights. The trim ring mounts differently, and the stud is fatter than a BLC or Guide. BLC and Guide usually have four rivets holding the base part to the bucket instead of five like those, and the rings on yours are slightly smaller diameter than BLC or Guide I think. Good luck figuring it out. Maybe if you take them apart and look all over the pieces, you might find some part numbers or brand names stamped in something.
Arrow uses a stiffener ring around the outside of the bottom mount like that. But the common Arrows have a shallower bucket and the ring attaches differently. Maybe they are an early Arrow? Or some weird Arrow model number? My common Arrows have the name and number stamped into the top of the bucket.
Anybody else got a guess? They came iwth the PU. I now find a 28 frame, 34 cab, cowl, and doors, and a 28-30 bed. Kind of a mixmatch, but will look good when I am done.
