Help to id a tranny,please
Discussion in 'The Hokey Ass Message Board' started by brad chevy, Sep 26, 2010.
  1. brad chevy
    brad chevy
    :confused: Trying to id this tranny,got it in some parts traded ,it was bolted to a sb Chevy scattershield,here are the numbers H3 c-81929 g 250939 on side shifter plate095664Z On small factory tag B-11x1 the side plate has 10 bolts holding it on.The vent is on top of tailshaft close to mounting bolts.Had a Hurst 4-speed shifter mounted to it.Any help will be appreciated,:confused: pictures wouldn"t load will keep trying.
  2. pcterm2
    pcterm2
  3. brad chevy
    brad chevy
    NO,definitly not a np435 this tranny is a side loader,.difference between it and Muncie,Saginaw and BorgWarner is it has 10 bolts holding the side shifter cover on.thanks for the try anyway.
  4. squirrel
    A833 mopar trans. here's one of the pics you emailed me, you need to make them smaller (resize) to get them to load here.
  5. squirrel
    oh here's the scattershield...the thick aluminum adapter should be the clue that it's not a GM trans :)
  6. pcterm2
    pcterm2
    now that i the see the pic -i agree with squirrel,a833 mopar
  7. brad chevy
    brad chevy
    Thanks fellows,is it a good Mopar tranny or just junk.?
  8. squirrel
    Depends what condition it's in. They were a good trans, worth swapping into a Chevy
  9. moparforlife
    moparforlife
    from Rolla, MO
    It is definitely a good trans. Looks like you have the 23 spline version. There was also a heavier duty 18 spline version for the Six Pack and Hemi cars. The 23 spline will take a lot of abuse though. It also looks like yours is the B-body version from where the shifter mounting pad is, probably made between '64 and '69. If it was a B/E body version, there would also be a pad near the rear of the trans. The input bearing retainer should be either 4.35 or 4.8 inches. Keep that in mind if you look for a different bellhousing.
