Help Throw Out Bearing.....
Discussion in 'The Hokey Ass Message Board' started by DYNODANNY, Oct 12, 2007.
  1. DYNODANNY
    DYNODANNY
    Well heres the cenerio.. Im currently putting my trans and motor together. I think I have to much clearence between my T.O. bearing and my pressure plate, I have about 1 1/2 in. clearence. It seems like much or is this ok? The motor is a dodge red ram 241 w/ a Wil Cap adapt kit to a 4 speed muncie. the clutch is all chevy 10.5 in. from a/c delco. Any help please....
  2. RichFox
    RichFox
    As I remember Chevy made a short and a long throwout bearing. Which one are you using?
  3. Is that 1/2" with the clutch release fork just flopping around on the pivot ball or is everything assembled in the vehicle?
  4. DYNODANNY
    DYNODANNY
    Thats with the fork on the pivot, lose. I think I have the short style bearing.
  5. DYNODANNY
    DYNODANNY
    Does anybody know about the two styles of throwout bearings for a four speed muncie?
  6. When you push the t/o bearing forward is the t/o arm out of travel room to disengage the clutch? If that's the case you do need a thicker t/o bearing. If there is still travel room then maybe it'll just be a linkage issue.
    Charlie
  7. DYNODANNY
    DYNODANNY
    yup I'm out of range? do you know what bearing I need? thanks
  8. Brad54
    Brad54
    from Atl Ga
    Yeah, sounds like you need the longer style throw out bearing. I know I have this kind in my '57 Chevy, and my '62 Chevy C10 as well. Strictly going by "well, it should be..." the longer bearing should be the same as at least up to '66 trucks.
    OR, find yourself a good mom&pop parts store and just ask the guy behind the counter for a long throw out bearing for a Chevy.
    I didn't know which I needed, so my parts guy hooked me up with both and told me to bring back the one I didn't need.
    -Brad
  9. DYNODANNY
    DYNODANNY
    Hey brad54 thanks for the info.
  10. DYNODANNY
    DYNODANNY
    I checked with my supplier and they don't know what I'm talking about. Does any one have any info for me? really need this resolved soon. any help please.
  11. kenagain
    kenagain
    from so cal
    you need the housing that bearing goes on there are two styles short and long style == parts house should have 2 different numbers for them just ask for something older n look at it you will see the difference quick
    Ken
  12. I took a look in the NAPA online catalog for the mid-60's clutch release bearings and find that 1/2 ton trucks have a different p/n than passenger cars. Can't tell from the info given what the dimensional differences are. If memory serves there are also a number of diferent length pivot ball assemblies available. A longer on might serve the need.
    Charlie
  13. DYNODANNY
    DYNODANNY
    Just got the bearing from my local parts store and its from a 60's 1/2 ton its about 1/2 in. orso longer. its from Federal Mogul part#614037. Thanks for all the help.
  14. The power of the HAMB.
