Hoping one of you fine folks can help me. I have recently had a new TCI mustang ii front suspension installed under my '59 Chevy. After trailering the cab and chassis home from the installer, I noticed one of the rubber bushings on top of the shock tower was torn up. Assumed this was a factor of not having the full weight of the body panels on the front end. Installed those. But at full load it's obvious to me that the shocks appear to be too tall. That is, even with the nut and washer bottomed out on the threads there is play in the shock, the washer is not squeezing the bushing at all. Do I have the wrong shocks? Pic attached showing how far above the tower the threads are. any advice would be greatly appreciated. I'm a bit of a novice to say the least but am determined to learn and do as much as I can on my own. Thanks in advance, Brian
