Hi, Would anyone know the 5 lug bolt pattern and stud size for a 1955 IH R100 pickup? I have to pick one up that is currently has rotted out wheels that are already removed, so I believe the lug nuts are missing, so I need to show up with wheels and lug nuts. Thanks for any help!
If it's half ton, should be 5 on 4.5 (ford, mopar, amc) Not sure of center bore diameter though, some Fords have a smaller diameter center bore.
Thanks, I just have to get it on a trailer. I have a set of wheels from a ranger pickup so hopefully they will fit enough to get it rolling. I know it is an oddball truck but I like them, I will bring 7/16" and 1/2" lug nuts. Just wanted to make sure it didnt have left handed studs or something to trip me up, will be a few hours from home.
5x4.5" bolt pattern, 1/2" studs with Right and Left hand treads. If i remember right stock ford wheels have too small a center hole, Mopar wheels fit, but with the more modern wheel you will have problems with the back spacing so the inside of the tire will contact the tierod ends, bring some washers or wheel spacers to space the wheel out to clear the tierod ends.
Thank you for that info..these ranger wheels are junk, I will take the plasma cutter them and open up the center hole to deal with that issue. Left handed lug nuts is a problem, that I dont have on hand. Maybe I can get lucky with NAPA or AZ, but somehow I doubt it.
If you don't have a local O'Reilly's, I looked up the same part (Dorman # 611-031) that Jim found for you, at NAPA and they also show it stocked under NAPA # NOE 6412025.
Thanks again for all the help, picked up 6 of the dorman lugs today at NAPA. Would be nice to have an oriellys around, they seem to stock more than the stuff at autozone or advance auto. Now tomorrow we will see how much of a nightmare it will be to drag home, and then a build thread in the future. Will be putting a jag front and rear suspension in it.
