hello out there i need a little help on wiring i dissassembled my car in 1986 and i need some advice on wiring my car is a 53 chevy 6volt car i put a 12 volt alternator in it but im having issues with the lights i put the wire the way i had them marked but could not read all of them on the front of the car by the radiator on each side is a small piece that the wires bolt to 4 on each side blinkers headlights and i need the color codeing or some one to tell whitch one is what when i turn on the park light the front work and none in the back and then when iturn on headlight the park lights go out and in all of this in confused if you have a original 53 54 car you could write down the colors or tell me where they go thanks alot or tell me where to go on the net for a good wiring dirigram thanks
this can be solved very easily with a test light. disconnect the wires at the junction and work the lights one at a time and mark what's what. then power each wire going out to the lights one at a time with a jumper, and mark what's what. then, match them up.
