i have a 3 rib 57-58 center section 29 spline posi unit the ring gear #s read 42-13 they are gm gears anyhow what ratio is this i know its been a topic lately thanks mike
Take the ring gear and divide by the pinion gear - that will give you the ratio. In your case, 42/13 is a 3.23 gear.
