I have a vintage Olds Weiand tri power aluminum intake. Has Weiand number W03D, I have a 57-58 [371] Olds tri power and the bolt holes look to line up but the ports on the Weiand are a lot bigger [ close to 1/2" taller] than the factory cast iron intake. Would this be for the 394 olds motors? Ports look like they never been enlarged. Someone changed the carburetor bolt pattern from 3 bolt to 4 bolt. Intake looks like it has never been installed.Any idea of correct application?
According to my Weiand catalog WO 3D came in 3 versions. Model WO 3D AB Part #7259 49-56 " WO 3D C " 7260 57-58 " WO 3D D " 7261 59-63 States that it is designed for extremely high speeds. Can be used with 3 Ford carbs or 3 dual throat WW Strombergs. State year when ordering. Oh and they were $92.50 in 1965!! Hope this helps.
Second series 371 and 394, '59-'64 Olds. Looks like carburetor adapters to fit larger Rochester's like Pontiac tri-power setups
