Help? Inline 6 Engine Number
Discussion in 'The Hokey Ass Message Board' started by 54LedSled, Jan 25, 2013.
  1. 54LedSled
    54LedSled
    I am trying to figure out what type of engine someone has. The serial number is 3921968. Inliners.org...stated 230-250...which is it? Ths. :D
  2. DUHH,,,what flavor,,,?
  3. 60srailjob
    60srailjob
    from nowhere
    where did you get the number,The number on the pad behind the distributor is the SERIAL # is this where you got it?
  4. 54LedSled
    54LedSled
    Yes, I believe he got it off the pad behind the distributor. How can I help him identify whether its a 230 or a 250?
  5. 60srailjob
    60srailjob
    from nowhere
    one's serial and one's casting, which may help to id the motor
  6. 60srailjob
    60srailjob
    from nowhere
    did you get the PM.
  7. Big T
    Big T
    from Florida
  8. 60srailjob
    60srailjob
    from nowhere
  9. 60srailjob
    60srailjob
    from nowhere
    this is for 66.....
    The 230
    • The 1966 Chevelles, El Caminos and Novas could be equipped with the 230-cubic-inch in-line six. The engine had a single-barrel carb, a 3.87-inch bore, 3.25-inch stroke and 8.5-1 compression ratio. It developed 140 horsepower and 220 ft.-lbs. of torque[​IMG]. Chevrolet kept the engine until 1969. The three-speed manual or automatic complemented the engine.
    The 250
    • The 1966 Chevrolet Impala and Chevy station wagons and trucks received the single-barrel carb, 250-cubic-inch six as the base engine. It had a 3.87-inch bore and 3.53-inch stroke with an 8.5-1 compression ratio. It developed 155 horsepower and 235 ft.-lbs. of torque. It continued to power Chevys and GMC trucks through 1984. The three-speed manual or automatic came with the engine.
  10. 54LedSled
    54LedSled
    Great, thanks for the info guys I'm trying to get more info from him. My question is are they worth anything? Would they be ideal for a early chevy say 1953/54 Chevy car? I imagine parts would be easy to find.
  11. Falcon
    Falcon
    from nevada
    The 250 valve cover is orange.
  12. Falcon
    Falcon
    from nevada
    Might get 20 mpg. Not worth much around here. Is it free to get it out of his yard?
  13. 60srailjob
    60srailjob
    from nowhere
    you can get ok (speed) parts.....
  14. Oilrag
    Oilrag
    from PA
    That casting # 3921968
    Began in 1973 and it's a 250
