Help IDing headlight buckets
Discussion in 'The Hokey Ass Message Board' started by PonchoJohn, Oct 14, 2012.
  1. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Hi Y'all-
    Can anyone ID any of these headlamp buckets?
    Thanks!
    Set 1 says Guide 903 J- what were they used on?
  2. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    2nd set has a light socket on the bottom- 1156 style
  3. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    3rd set- these have a triangle mount on the bottom vs the BLC 682 style-??
  4. First set of pic,s, if they are real round to look at, not bullit shaped. International truck.
  5. sololobo
    sololobo
    Easy to I.D., very damn cool!! ~sololobo~
  6. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Any ideas on the 2nd and 3rd sets? The 2nd set w/ the lamp socket confuses me?
    Thanks!
  7. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Anybody seen the 2nd set w/ the aux. lights on the bottom before?
  8. Ghost28
    Ghost28
    I don't believe that's a light socket on the second set. I think the hole is for for the wiring to go through.
  9. F&J
    F&J
    I agree. Those sockets are like the much older OEM headlights that had the armored cable that plugs in, just like a bulb socket.
    Other lights had just a hole with a grommet for the wires to run out, or some even had wires going through a hollow mounting bolt.
  10. SASROD
    SASROD
    International headlights posted by 34 GAZ actually look like these, the headlight has a concave mounting socket, with large cast iron brackets. These two pictures I posted are the same lights. The are also stamped "GUIDE" (no tags) with no numbers, if I remember correctly. They are much rounder looking than most, though.
