Can anyone help me with the year of these headlamps. I think the ones that are 10 1/2" are '32s but not sure on the smaller ones. Also does anyone know where I can get replacement lenses and reflectors that convert to halogen/turn signals. Saw a set in MAC's but not sure if they will work. thanks
Look like model a lights with adapter rings to swap over to sealed beam. That was a common modification to get better lighting. Don
The ones with the sealed beam conversion look like 30-31 Model A. The original lense is close to 8" diameter. The bigger ones probably are 32. need to see a side profile of both sets.
Thanks I'll send pics tonight. I think the larger are 32s as well. I'd like to convert them back to traditional lenses.
Assuming the light on the right is a Model a headlight, Snyder's Model A parts has what you need. http://www.snydersantiqueauto.com/3830 http://www.snydersantiqueauto.com/3813
Here's the mockup of the headlamps on my 28 roadster. Grille is off earlier model T but gives general idea. Think i'm going with the smaller ones but converted back to lenses.
