Help identify this Rearend
Discussion in 'The Hokey Ass Message Board' started by kustomolds, Aug 23, 2010.
  1. kustomolds
    kustomolds
    OK, boys, need some help here...
    This rearend is in a '36 Dodge 5window coupe. I have a feeling that its the original, but just want another opinion (or two)
    Thanks!
  2. redsdad
    redsdad
    57-64 Olds/Pontiac heavy duty (3 rib)?
  3. kustomolds
    kustomolds
    It has the slip joint instead of U-joints and the drums are on a taper with a key-way/castle nut (i would post a picture, but don't think i have one.)
  4. R Pope
    R Pope
    See how the pinion shaft is in line with the axle shafts, not below them as in modern hypoid gearsets? That makes it an older unit, prewar. The ball-and-trunnion U-joints and tapered axles say it's a Chrysler-built rear, so I would guess it's the original one for your car.
  5. oldandkrusty
    oldandkrusty
    Tapered axles and trunnion U'joint definitely say "Chrysler" to me. My guess, like R Pope's, is that you are looking at an original.
  6. thunderbirdesq
    thunderbirdesq
