Help identify Ford tranny
Discussion in 'The Hokey Ass Message Board' started by d.reese, May 23, 2011.
  1. d.reese
    d.reese
    Help identify Ford tranny! 4 speed, case to tail section 24" long, main shaft 10 spline, the main shaft housing 1-3/8 OD, out put 27 or 28?
  2. propwash
    propwash
    from Las Vegas
    Dagenham? Used behind LoPo Fords (6 cyl Mustangs, Falcons, etc)
  3. looks like a 60's toploader for a big car - Mustang shifter mounted closer to the main body if I'm thinking well....the ID year should have a C for the 60's - D for the 70's.....after that is the year C6 - 1966, C7 - 1967 and for the D...D0-1970 and D1- 1971....someone correct me if I'm wrong...
    I was at YellowBelly....looking thru your book....good resto on the goat...
    Lawrence
  4. screwed with them Dadgumum's many a time.....they're itty-bitty next to a T-10 or a TL.....just saying
  5. d.reese
    d.reese
    numbers
  6. T-Time
    T-Time
    from USA
    Those aren't the "numbers" you need to identify a toploader 4-spd. You are looking for a number like RUG-XXX or HEH-XX.
    Here's where you will find a fairly complete code list once you locate the code on your tranny:
    http://www.falcongt.com.au/toploader.html
    That said, the maincase engineering number shown in your photo was used from 1968-71. The tailshaft engineering number shown is the same as used on the so-called toploader "imposter", i.e. the three spd toploader with overdrive. I don't think any "real" toploader used that tailshaft. It might be a mix and match of parts. That's common with toploaders as they tend to get changed around over the years..
  7. sick467
    sick467
    from Missouri
    Looks like a 68 Toploader - Stillrunners was on the right track.
  8. d.reese
    d.reese
    Tail shaft is off a OD Imposter, but tranny is a 4 speed!
    So what would one of these be worth?
  9. d.reese
    d.reese
    Thank you, thats my 1st frame off resto. So you know that means a lot!!
  10. hobbs53
    hobbs53
    from leo, In.
    I've got a 3 speed out of my '59 F100.....numbers i find on the casing are:
    4DI3 (or 4D13)
    CA8R
    7006 E
    BS
    any info on what tranny this is?
