I picked up these aluminum backing plates and finned drums they looked cool they were cheap and I was hoping they would work on my model axle, I think I can make the drums work with a modified hub not to sure about the backing plates though drums are 9 1/2 inch inside diameter and the backing plates are 11 outside diameter.
don't know what the backing plates are off of, do they fit the drums? or are they too big? the drums might be late 70s GM midsize car, they had aluminum drums 4.75" bolt circle, I think 9.5" diameter. but the backing plates looked nothing like those.
No I the drums and backs dont go together, I might have picked up the backing plates in the VW area, The guy said he thought the drums might be from a Nova.
If their Nova, would adapting the backing plates to the ford axle be about the same as you have to do with other backing plates where you drill the propper holes.
i looked it up, the drums are the ones I thought, late 70s midsize GM. I got a pair off a 79 monte carlo years ago. do the backing plates fit the drums? the inner lip of the drum should fit into the indent in the backing plate, if they're the right size. My guess is the backing plates are for a larger size brake.
No the two do not mate up they come close though, the arm in the backing plate that swings the brake pad out, its only a few fourths an inch away from the inside of the drum. I dont think the two could be used together but they sure would look sweet if they did. I'm only gonna be able to use one of them on my axle, if one will even fit after alot of modification and adapter
Backing plates look to have a Mopar 8 3/4" five bolt pattern to them. I can't think of anything else that uses five bolts off the top of my head. Not the right diameter though.
Five holes were used on some Fords too, and probably some other things like Danas installed in other makes of cars. the bottom hole is a drain for anything that leaks past the seal, so it won't contaminate the brakes.
could be dana. im still thinkin ford...but definitely steel....even looks like rust on one in the one picture
Just an update for Von, the backing plates are steel. tested it with a magnet! they looked like polished aluminum.
