Technical Help I'd schiefer aluminium flywheel
Discussion in 'The Hokey Ass Message Board' started by jambottle, Nov 29, 2019.
  1. jambottle
    jambottle
    This flywheel is counter balanced. The number on the flywheel is 30-22023. Hoping I can use it on my buick nailhead
    I appreciate any help you can give.chris
    Sent from my SM-G960W using The H.A.M.B. mobile app
    dana barlow likes this.
  2. jambottle
    jambottle
  3. Jalopy Joker
    Jalopy Joker
  4. Black Panther
    Black Panther
    from SoCal
    Chris...look on the side of the ring gear and see what the tooth count is..I'll look it up when you report back..
  5. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Are all things same,bolt pat,ring off set,and If your engine has a factory steel or cast flywheel,you can kind of check balance, with a bubble wheel balancer= must put both wheel together lined up,but with one wheel{ 180* to other wheel=if new wheel has same "Off/counter balance as old wheel" then they will set fairly level on wheel balancer,if they lay off to one side"no,you need new matched to old. The one being 180* is so offset balance is opposite each other for a match..
  6. Black Panther
    Black Panther
    from SoCal
    20191204_144853.jpg In the meantime...this is the resource I go to first to identify old flywheels...it is from my 1968 Bell Auto Parts catalog..
    kidcampbell71 likes this.
  7. Black Panther
    Black Panther
    from SoCal
    Tooth count narrows your search big time...if there happens to be a couple with the same count..then you can narrow it down further with the crank bolt pattern..
  8. Pass The Torch
    Pass The Torch
  9. jimmy six
    jimmy six
    Old cast flywheels have been known to come apart and are outlawed by racing organizations. I’m not saying not to use it; but realize what you have....
  10. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Alum flywheel is one of those things too use were needed,and pass up on if not ,vs a steel flywheel. Thing is if its a vary lite car/say under 2500 lbs. and your really looking for good drag race speed,it is great, But in a car of 3000+,using alum wheel is going to slow you down. Bigger cars need the steel to get it going start an each shift. I'm only talking ,as have seen some use things,just thinking it was sexy. But we can't see a flywheel. I talked about balance a few post above.
  11. jambottle
    jambottle
  12. Beanscoot
    Beanscoot
    "Old cast flywheels have been known to come apart and are outlawed by racing organizations. I’m not saying not to use it; but realize what you have...."
    Aren't these flywheels forged?
  13. Also aluminum flywheel are for high revving engines so I would be careful using it just a word of advice.
  14. Black Panther
    Black Panther
    from SoCal
    As far as 153 tooth flywheels in my catalog. ...looks like there are two. Chevy with 10.5 clutch..or big block Ford. The Chevy has the extra hole in the pattern like your flywheel. Measure the iron insert..if measures slightly less than 10.5"..its for Chevy.
    Desoto291Hemi likes this.
  15. jimmy six
    jimmy six
    Not all of them.
  16. Beanscoot
    Beanscoot
    The Schiefer / Alcoa flywheel in the first pictures sure looks to have forging metal flow lines, the Weber catalog says they are forged and "Guaranteed Blow-Up Proof".
    Are Schiefer and Weber flywheels one and the same thing?
