Help.. ID Chrome Fuel Pump
Discussion in 'The Hokey Ass Message Board' started by matthewsgarage, Dec 12, 2012.
  1. Not sure what this chrome fuel pump fits. If any body knows it would be very helpful. Thanks,Tom
  2. titus
    titus
    im guessing flathead
  3. Look at the cup for the push rod it is turned around,glass bowl would be on top. Not sure if that would work ????
  4. you think it was any old aftermarket pump
  5. titus
    titus
    fuel pump on my wifes 54 delivery has the glass bowl on top
    Yep, thats what i would think, aftermarket
  6. I'll give it a try,see what happens.thanks
  7. titus
    titus
    this one kinda mounts upside down too.
  8. titus
    titus
    just make sure you put a new sediment bowl gasket on it.
  9. antiqueautomike
    antiqueautomike
    from Spokane
    It is a flathead pump, probably a aftermarket replacement. All AC fuel pumps have a 4 digit #. Most are on the mounting flange sometimes it is a tag held down with a screw. If this pump has a # I can most likely tell you what it fits. Carter pumps also have a code. But, in Carter carburetors infinite wisdom they never kept a good record of what the # fit. They intended to sell new pumps not rebuild them.
    Mike
  10. I see no #'s anywhere, also pump is much larger and heavier then a stock flathead pump.
  11. propwash
    propwash
    from Las Vegas
    for you "it's upside down" folks - that cup swivels - so it can go either way. Flathead is also my guess. Looks to me to be aftermarket, and that's quite likely if there are no numbers anywhere.
  12. titus
    titus
  13. titus
    titus
    The fuel pump boss pattern is not symetrical so it can only mount one way.
  14. Ok, so that does not work. Bottom of pump hits the intake manifold. Is there a higher fuel pump stand for this type of pump out there. I have been working on flatheads for a long time and do not know of any but I also did not know nothing about a "bus pump" also. So any suggestions ??? Thanks for any info. Tom
    303racer likes this.
  15. titus
    titus
    Not sure on that one, some of the intake have the fuel pump stand turned, dunno if they make a stand with a different clock.
    i do think they list 2 different lenght fuel pump pushrods so maybe they do, i have a box of stands but wont be able to dig them out till tomorrow, ill take a peak at em then.
    jeff
  16. Andy
    Andy
    You have a 8ba engine and they use the angled pump mount. I had to make a 3/8 spacer for my pump on a Offy manifold because it was really a 8ba design that they sold as a 48 and earlier. I had to add to the rod too.
    I think it is a high volume pump for a flathead.
  17. ok,i did not think of that. i will check and see also if i have any 49-53 stands.thanks,tom
  18. hari kari
    hari kari
    from michigan
    Wow that is on old high volume bus pump. Back in the day that was what they ran on 3 or 4 carb setups...very rare and $$$
