Looks like i might have a bad valve seat in my flattie. Has anyone out there removed one before? Any help will be great. Thanks guys. Jerry
dont they have a tool for that i think my dad bought one at speedway. yeah they got one 19.95make sure you puts some wd on them first
Seats are hardened, not easy to drill. Old way was/is to use a very sharp chisel, one or two blows and they split, then you can pry out. DONT hit the machined area! For installing with the engine in the vehicle you need to heat the block valve area SLOWLY and then tap in the new seat which has been in the freezer a few hours. Have a fire extinguisher handy if there is a lot of crud in the lifter chamber. If you dont have adjustable lifters you may need to shave a few thou off the new stem to match the old length. Lap in the new valve and button it up.
I believe another way would be to use a mig welder are run a bead around the inside of the seat. This will shrink the seat and it will just about fall out. I have used this method on other pressed in items which would not cone out easily. (seal on transmission output.)
Tootallrodder has probably the least destructive way to remove them. Any time a hammer and chisel is involved there is a chance of a misdirected blow and unwanted damage. By simply running a weld bead around the inside of the seat the resulting shrinkage will almost always allow the seat to fall out. If not it will be loose enough that just gentle persuasion will remove it. Frank
Thanks you all. I have used the welding method at work before on bearings and it worked out great. thanks again guys. Jerry
Never did the Mig trick, wasnt something that we had in the pits when I learned most of this shit; but it sounds like I need to give it a try sometime. Since a MIG is not in very many backyard rodders inventory the hammer and chisel still works fine. But as I said, be careful where you hit AND wear eye protection.
